09-07-2011, 06:32 PM   #1
Setting the focus point
Is it possible to assign the rear e-dial to scroll through the focus points while in AF SEL mode? Seems to me like a better, faster way to select which focus point I want to use.
09-07-2011, 07:00 PM   #2
joe.penn's Avatar
QuoteOriginally posted by Franky2step Quote
How will that work? You won't be able to select any of the points up/down
09-07-2011, 07:06 PM   #3
Coming from a Canon 5D MKII, I could toggle through all the points, stop at the point I wanted. Seems like an easy thing to do. The four way pad ends up changing other parameters when I use(attempt to use) it.
09-07-2011, 07:29 PM   #4
joe.penn's Avatar
When using the 4-way, engage it by pressing the "ok" button first - when pressed, you will see the directional marks appear on the focus square then use the 4-way to move to the point you want...
09-07-2011, 07:35 PM   #5
I will give it another shot but the last time I tried, I was changing all sorts of stuff
09-07-2011, 08:51 PM   #6
johnmflores's Avatar
You gotta press until you hear the beep, then the 4-way pad will adjust WB, drive mode, etc. Press until you hear the beep again and it toggles back to adjusting the focus point. Not perfect, but it works.
09-07-2011, 08:55 PM   #7
joe.penn's Avatar
I actually didn't realize it beeped - I have the sounds turned off
09-07-2011, 10:04 PM   #8
QuoteOriginally posted by joe.penn Quote
that's the only thing I have the beep turned on for...at the moment.
09-07-2011, 10:08 PM   #9
Smeggypants's Avatar
Of course you will.. Scrolling through the AF points would include al of them on the screen regardless of their position. Simply stop on the one you want.
09-08-2011, 07:15 AM   #10
thanks, works like a charm...had the sound off, kept pushing the OK button. Everything is good now. Thanks again
09-08-2011, 10:56 AM   #11
But what about the original question? Can you assign the focus point control to a wheel? Or might there be a possibility of this option in a firmware update?
I borrowed a friend's Canons until I got a K20D to tide me over until I could get a K5. There are a *lot* of things I like better about the Pentax, but controling the focus point seems cumbersome compared to the ease of scrolling through them on a wheel.
09-08-2011, 11:18 AM   #12
Wheatfield's Avatar
QuoteOriginally posted by wzdevito Quote
No, you can't.
camera, dslr, focus, k-5, k-5 ii, k-5 iis, k5, pentax k-5
Setting centre focus point in green mode NogBoy13 Pentax K-5 12 07-28-2011 06:50 AM
setting infinite focus sany Troubleshooting and Beginner Help 7 05-07-2011 05:43 AM
Pentax K7 (Setting Focus Point) Please Help Borislav Pentax DSLR Discussion 9 04-10-2010 03:13 PM
K100D Super - Focus point locked to center in Manual Focus ? JGabr Pentax DSLR Discussion 2 01-25-2010 09:41 PM
Setting up focal point for manual lenses. consider crop factor? D4rknezz Troubleshooting and Beginner Help 7 09-23-2009 01:00 PM
All times are GMT -7. The time now is 04:49 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
