Originally posted by Flick Have any you experienced a noticable loss in quality / sharpness when using a converter on say a 300mm zoom lens, and can someone direct me to some sample images? I need more reach; options are 1) get a converter, or 2) fork out the money for a larger lens...?
There will be a significant loss in image quality.
A tele converter however still delivers more resolution than a good prime lens alone. You'll have to use the lens at its sweet spot (like f/5.0), and you'll have to sharpen more which means you better shoot at low iso when using a converter. So, a converter "eats" at all ends: less aperture, faster shutter speed and lower iso.
However, if for some reason you absolutely need the resolution, a good prime with a converter can't be beaten by a longer consumer zoom at its long end (or a bargain 4 element tele lens). So, the only alternative to a converter then is very expensive glass ($4000+ range). For all camera systems. This is why in my blog, I proposed Pentax to make a $2000 500/5.6 lens to make a fresh and unique offering to the market.
In practice, it means that longer reach is impossible except at sunlight with a converter and the DA* 300mm or the DA*60-250 at 250mm. However, converters supporting autofocus with SDM lenses are rare (some very specific Tamron 1.4x and the Pentax 1.7x) and AF then is slow.
Therefore, you are normally better off cropping. Note that a 4MP crop from a K-5 with a DA*300 corresponds to a lens which is at 35mm film equivalent to a 900mm lens ... And only very few long tele shots resolve better than 4MP...
I have a 500mm lens but believe me, it is hard to use with a moving subject like a bird. Framing becomes an art, not to speak about focussing
With a static subject, you can also shoot a short burst of 4-6 frames and use super-resolution (cf.
PhotoAcute) to extend your reach.
