09-18-2011, 06:57 PM   #1
Sigma18-250
Just wondering if anyone here is using the Sigma 18-250 with a K5? Why does it have built in Image Stabilization? How does it do in low light? I've narrowed my search between the Sigma, and the Pentax 18-135mm.
09-18-2011, 07:03 PM   #2
Sigma is starting to put OS in a lot of their lenses - it looks like people like it: Sigma 18-250mm F3.5-6.3 DC OS HSM Lens Reviews - Sigma Lenses - Pentax Lens Review Database
I wouldn't use this lens after sundown. Even the 18-135mm is a stretch for low-light photography. You'd need something faster for that, IMO (a prime perhaps).
09-18-2011, 07:46 PM   #3
hcc
hcc's Avatar
The Sigma 18-250mm OS HSM is currently the only 18-250mm all-around lens available new for Petnax K-mount. Like all all-around zoom, the lens is a compromise and its weakness is the low-light.
In terms of IQ, there have been a few threads and the consensus is that the Sigma 18-250mm OS HSM IQ is on par with the IQ of the DA18-250mm/Tamron 18-250mm.
When comparing the Sigma 18-250mm OS HSM with the DA18-250mm/Tamron 18-250mm, the Sigma OS allows to see in viewfinder the image after stabilisation. On the other hand, the lens OS is redundant with the camera SR. In practice one, the camera SR or the lens OS, must be switched off. Myself, I do a lot of bushwalking and use my camera in rugged conditons. I regard HSM as a mechanical impedement and I value the simpler mechanics of the DA18-250mm.
Hope that the comments will help.
09-18-2011, 08:54 PM   #4
On a K5, do you really think it would be a problem?
09-18-2011, 08:57 PM   #5
hcc
hcc's Avatar
For low light, you need to use a fast lens: large aperture and low f. Like f1.4 or f1.8.
While the K-5 has great abilities at high ISO, the use of high ISO cannot replace the large aperture of these fast lenses.
Many 18-250mm lens users will travel with a small fast prime lens (in their pocket) for very low light conditions. I do.
Food for thoughts
09-18-2011, 09:06 PM   #6
QuoteOriginally posted by hcc Quote
Food for thoughts
Well I do have an old Super Takumar f1.4 50mm, but traving in Italy may present a problem changing lenses, especially with the fact that it's a screw mount, and will need the adapter.
09-18-2011, 11:09 PM   #7
RioRico's Avatar
QuoteOriginally posted by Tony3d Quote
The trick there is to get a cheap clone adapter. Remove the screw and clip. Put a bit of metal tape on the lens base to safely short the mount contacts so you can use CIF (catch-in-focus). Use a rear lens cap as a wrench to tighten the adapter on the lens. Now you can treat the lens as a K-mount in Av mode. Easy to swap lenses when you go indoors or shoot at night.
09-19-2011, 10:00 AM   #8
falconeye's Avatar
I recommend a used DA/Tamron 18-250.
The reason is DxO: images treated with their lens module are two classes higher. Well, with enough light / low enough ISO at least. DxO has no lens module for the newer Sigma 18-250 and the IQ of the Pentax 18-135 seems to be weaker despite the more limited zoom factor.
09-19-2011, 06:10 PM   #9
Smeggypants's Avatar
Youll be fine in low light with the K-5. I regularly shoot in low light with my Sigma 135-400 f4.5-5.6 using high ISO to get the shutter speed above the camera shake zone. Works really well even sometimes above ISO6400
of course a fast prime will always be be better at it's focal length of the fast prime. I have several fast primes and love the shallow DOF and low ISO usage these lenses get. but then the prime has one focal length and it won't be 250mm.
09-19-2011, 06:18 PM   #10
audiobomber's Avatar
That Photozone test is bunk. I don't blame Klaus, he tried to have Pentax fix or replace the lens. I tested my 18-135 vs my DA L18-55 and DA 18-250. Wide open at 18, 55 and 135mm, it was sharper that the others across the frame. Mechanically it is in another league entirely.
camera, dslr, k-5, k-5 ii, k-5 iis, k5, pentax k-5, sigma
Pentax 18-250 vs. Tamron 18-250 amalongi Pentax SLR Lens Discussion 22 09-19-2011 12:26 PM
Sigma 18-250 or Pentax/Tamron 18-250? mjbens01 Pentax SLR Lens Discussion 3 07-08-2010 09:10 PM
Pentax 18-250 always same as Tamron 18-250? kitkat Pentax SLR Lens Discussion 12 07-08-2010 08:30 AM
For Sale - Sold: Sigma18-50mm F2.8 Macro $350 waynes Sold Items 7 12-05-2009 11:25 AM
Why DA18-250 is double the price of Tamron 18-250? raider Pentax SLR Lens Discussion 6 12-13-2008 05:40 AM
All times are GMT -7. The time now is 05:50 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
