09-27-2011, 11:40 PM   #1
Manual white balance problems on K5
I hope somone can help me out with this ...
I set a MWB but got a terrible blue colour cast, now I just can't get rid of it
When I try to replace it, with a gray card reading for example, it hardly changes at all. Sure I can use the other 2 MWB settings but how do I make a wrong setting go away?
I've RTFM but that's no help at all and I've done a search here to no avail.
What am I missing here?
Any help will be greatly appreciated.
Graham
09-28-2011, 01:52 AM   #2
dragra's Avatar
QuoteOriginally posted by 2grahamb Quote
Graham
Shoot RAW.
09-28-2011, 02:10 AM   #3
As I only ever shoot RAW that's not really the answer I was looking for dragra.
Even shooting RAW exclusively there are times I'd like to set WB using a gray card to get a consistent WB. I often find the K5s AWB to be too cool and fiddling with it in LR3 isn't always successful I find. That Tint slider is very sensitive and hard to set to what I want.
So just how do you delete a MWB setting in camera? It doesn't seem to be that easy or I'm missing something.
Graham
09-28-2011, 02:32 AM   #4
dragra's Avatar
Graham
I don't quite understand your workflow. All you need to do is shoot a gray card in RAW - all the rest of the magic you do in Lightroom.
If it's hard for you to catch the WB slider you can also enter precise numeric color temperature values.
Cheers,
D
09-28-2011, 02:53 AM   #5
You don't delete it as such, you just overwrite it the next time you need a manual white balance.
Regards,
--Anders.
09-28-2011, 05:56 AM   #6
That's just it Anders, when I attempt to overwrite it the previous colour cast setting still has an influence on the new MWB. I thought there might be some way to delete it but maybe there isn't.
09-28-2011, 08:11 AM   #7
That sounds odd. Are you in a USER mode, or one of the plain P,A,T,M modes on the program dial? I'm asking because the USER modes affect how settings persist.
Sincerely,
--Anders.
09-28-2011, 08:37 AM   #8
When you are in the WB Adjustment area, press the Green Button to recenter the WB. Then you can just start over. Why you cannot get a satisfactory one however is beyond any help I'm going to be able to provide.
09-28-2011, 07:02 PM   #9
No I only use M, TAV or AV mode and occassionally User, but not when I had this issue.
I managed to overcome this issue by shooting a gray card then in Playback Mode pressing the 4 way down button and saving the WB as a MWB. This then overwrote the colour casted setting. As dragra wrote above I could just shoot a gray card then sync the WB in Lightroom, but sometimes I want to set WB in camera instead. Thank you all for your help.
Graham
09-28-2011, 07:06 PM   #10
QuoteOriginally posted by JeffJS Quote
Thanks for the input Jeff, but the setting was already centred and whatever I did I couldn't get rid of the colour cast.
See my other post below/above?? for my workaround.
Graham
09-29-2011, 01:06 AM   #11
Sorry to say: Yes, my K5 (siver if any importance) has a poorly MWB ( toward Samsung GX20-perfect MWB), but not horrible. AWB is good only in the low domain of color temperature, but has a blue color cast (little one) in the high domain. There is possibility of adjusting this deviation if they are not to large. If is impossible to obtain good color balance, this can be a defective camera.
Verify your setting in Menu/ C2/ 10. WB Adjustable range/ 1. Auto adjustment or 2. Fixed. If Auto adjustment is selected, there is a possibility (not verified by me yet) in camera to change (tune) your original MWB setting .
Question: the poorly MWB appears on the LCD of the camera identic to the LCD of the computer for the p.p.? If not, there is possible of wrong balance of color in one display or even two.
camera, dslr, help, k-5, k-5 ii, k-5 iis, k5, pentax k-5
White balance problems with kx heralu Pentax DSLR Discussion 11 02-16-2011 03:39 AM
K-5 White Balance problems conroy11 Pentax K-5 7 12-25-2010 07:38 AM
Frustrated with KX Manual White Balance for IR... Internetpilot Pentax DSLR Discussion 5 06-15-2010 01:30 PM
Manual Focus + white balance yusuf Pentax DSLR Discussion 6 04-25-2010 09:55 AM
K7 White Balance Problems jacksonpritt Pentax DSLR Discussion 13 01-05-2010 05:46 PM
All times are GMT -7. The time now is 10:30 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
