10-05-2011, 03:08 PM   #1
veato's Avatar
Oh no, K5 is broken!
Well I discovered today the lens release button on the K5 has fallen off. It hasn't been dropped or anything, I just pulled the camera out of the bag and it was minus the button. If I reattach it it just falls off again.
Looking on the net it seems it's a bit of a common fault. I've only had the camera 6 months.
I'd normally go back to the store in the UK and let them take care of it but I bought it off Simply Electronics and I have zero faith in them. Time to dig out the receipt and contact Pentax!
Has anyone else:
a) Had this fault?
b) Had it repaired under warranty by Pentax?
c) Not had the fault return?
10-05-2011, 03:21 PM   #2
Senior Moderator
Parallax's Avatar
https://www.pentaxforums.com/forums/pentax-k-5-forum/147149-lens-release-butt...-my-k-5-a.html
10-05-2011, 03:36 PM   #3
twitch's Avatar
Ouch, sorry to hear that, this is becoming an epidemic.
10-05-2011, 03:44 PM   #4
Wheatfield's Avatar
Must not say anything lest I get squirrels flinging poo directed my way.
10-05-2011, 03:48 PM   #5
Ash
Community Manager
Ash's Avatar
Sorry to hear.
Never experienced with my own copy, but clearly you're not the first case, and you probably won't be the last. All the best in having it repaired.
10-05-2011, 03:50 PM   #6
veato's Avatar
I'm thinking I should check for sensor stains before I send it off too
10-05-2011, 03:59 PM   #7
Senior Moderator
Parallax's Avatar
10-05-2011, 04:25 PM   #8
Ex Finn.'s Avatar
Damn.
10-05-2011, 05:58 PM   #9
mickey's Avatar
The SR switch broke off my K10d a long while ago, which was quite common back then on some batches.
Like you experienced, it wasn't through misuse, I hardly ever switched it off, only when I used my tripod which wasn't very often.
Took it to Pentax and they seemed to be familiar with this problem.
It was fixed and returned within in a week or so.
I'd say get it sent off quickly and you should be good to go.
10-05-2011, 07:24 PM   #10
Smeggypants's Avatar
it would abort.
10-05-2011, 08:43 PM   #11
Sorry to hear this. I would check for stains as it'll need a repair trip regardless.
Would you mind posting your SN and mfgr date (can get this via exif data), just in the chances this may eventually turn out to be limited to a range of cameras (or it may also indicate otherwise/all cameras with enough people reporting).
10-08-2011, 07:19 AM   #12
Sorry to here this as I would like to upgrade my K20 but my feeling with the brand after reading all these defects prevents me from moving forward. My view of the brand is.
If one believes as I do the Ricoh management was in place 12 months pervious to the Oct 1st transfer on the books as it would be typical for an operation of this nature. The QC of the brand my not improve as it has already been established.
10-08-2011, 08:36 AM   #13
Tom S.'s Avatar
Nonsense! I heard the poo works very well for reattaching the button.
10-08-2011, 07:23 PM   #14
QuoteOriginally posted by Tom S. Quote
Only if the squirrel gives up his nuts and sticks to a high-fiber diet...
button, camera, dslr, fault, k-5, k-5 ii, k-5 iis, k5, pentax, pentax k-5
Broken ME, want to take apart Capslock118 Pentax Film SLR Discussion 12 11-12-2010 05:19 AM
Lens is broken: broken mount nemo9439 Pentax SLR Lens Discussion 4 08-27-2010 09:52 AM
IS broken? sealisthenewbeaver Pentax DSLR Discussion 16 08-17-2010 07:00 AM
Broken dreams, broken camera brkl Post Your Photos! 3 03-10-2009 05:08 PM
All times are GMT -7. The time now is 08:30 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
