03-07-2012, 07:47 AM   #16
v1.13 K-5 still same problem
03-08-2012, 01:25 AM - 1 Like   #17
I followed your instructions and it really works flawlessly Thanks a lot Man!
QuoteOriginally posted by tx0h Quote
hi,
solder a 1k Ohm resistor
between trigger / middle
contact and flash mainboard
connector.
in the picture:
Resistor Color Code:
brown black black brown
with 1% tolerance (brown)
please send fail or succeed
stories.
thanks,
tx0h
warning, this will break the warranty and may damage equipment, this is a standard disclaimer and you really can't blame me if somethings get broken.
03-08-2012, 01:38 AM   #18
Anvh's Avatar
QuoteOriginally posted by supersimon27 Quote
Why should Pentax fix a problem from a different company?
03-08-2012, 08:30 AM   #19
tx0h's Avatar
QuoteOriginally posted by ShutterMinds Quote
WOW!
thats so cool! a success story!!
thanks for let us know, this may encourage
people to take the solder iron in the hand
and put this dumb 1kOhm resistor in place.
greetings,
tx0h
03-08-2012, 07:41 PM   #20
This is also a problem with my ricoh grd iv, but I can't bother fixing it, since I use the flash from wireless triggers and they fire just fine.
06-22-2012, 12:33 PM   #21
Filip Latka's Avatar
It didn't work with mine ! Yn560II looks different inside, more cables. Green and yellow:/ HELP!
06-23-2012, 09:21 AM   #22
tx0h's Avatar
QuoteOriginally posted by Filip Latka Quote
Hi Filip,
OK, thats another flash type.
Which method did you try?
The capacitor (#7) or the
resistor (#15) method?
greetings,
tx0h
06-23-2012, 12:01 PM   #23
Dear Sir!
Thank you for your quick reply,
Im pretty much poor in any hardware modifications, so I asked my friend to help me out, he tried with most of the cables I guess[resistor not capacitor],
What we achieved is ''sound'' button makes sound now when you press it [didn't before], flash goes back to normal after removing it from the hot shoe, before I had to take all batteries out to restart.
Current configuration : All sizes | _FIL1817 | Flickr - Photo Sharing! , All sizes | _FIL1818 | Flickr - Photo Sharing! , http://www.flickr.com/photos/filips131/7427256008/sizes/h/in/photostream/
Please help me! I am so frustrated !
Thank you !
06-27-2012, 09:45 AM   #24
Hi Filip,
greetings,
tx0h
Sir ! Just wondering now if they sold me correct resistor! :/
Mine is different than yours, brown/silver/black/black/brown.
Will this make anything if the number is higher ?
06-28-2012, 05:28 AM   #25
tx0h's Avatar
sure this makes a difference. you soldered a 1Ohm resistor and not a 1000Ohm resitor.
the reading is brown black black silver, btw. should be brown black black brown.
a 1Ohm resitor may not make such a big difference, but 1k Ohm is a 1000 times
stronger resistance and i would give it another try. such a resitor is very cheap.
greetings & report back,
tx0h
06-30-2012, 10:19 AM   #26
Wow! I ll defo give it a go 2moro or day after! Just wondering which cable I should deal with. I understand the green one is instead of red in 560 II Thank you for your help!
Cheers!
07-07-2012, 09:48 PM - 1 Like   #27
I'm so excited. Thanks to the suggestions on this thread, 45c for the resistor and my Dad's soldering skills I now have a YN-560 II that works on my K5. We attached the resistor to the yellow wire. So excited! Thanks again helpful people.
01-22-2013, 08:24 PM   #28
update
I just ordered this flash, YN560II, and I was prepared to do this when it arrived. Well I didn't do this yet,andI have been using this with my pentax k5, and so far I have no issues. I took the bottom apart and mine looks different from the other pictures above, so maybe yongnuo updated their flash to fix issues like this?
01-24-2013, 04:20 PM   #29
tx0h's Avatar
QuoteOriginally posted by mayday295 Quote
i'm sure there is such a resistor in the heat shrink tube. so yours is fine :-)
10-03-2013, 02:51 PM   #30
maxk7dish's Avatar
Hey, this sure is an interesting thread, and thanks all who have contributed fixes. I have the original 560, same as the one in the original fix. I tried both a .1uF and a .01uF capacitor and neither worked. I know the flash is fine as it fires reliably when connected to my triggers. However, my transmitter has a similar issue as well. It works about 5% of the time when attached to my K5 IIs hotshoe, but 99% of the time when unattached.. Considering that my transmitter is also having issues, though, I can't help but wonder if there is something wrong with my hotshoe, and not the triggers/flash. I have not tried a resistor instead of capacitor, will see how that goes. Anyone else think this could actually be a QC issue with K5 hotshoes?
base, camera, dslr, firmware, flash, k-5, k-5 ii, k-5 iis, k10d, k200, k5, k7, pentax k-5, photo, time, wire, yn560
$2.75 omni-bounce-like Flash Diffuser for YN-560 geekette Flashes, Lighting, and Studio 8 06-12-2011 10:24 PM
Good manual flash under $100? (Besides YN-560) geekette Flashes, Lighting, and Studio 4 05-27-2011 12:55 PM
Yongnuo YF-560 Flash - a strobist review of it philbaum Flashes, Lighting, and Studio 64 05-13-2011 07:01 PM
yn-560 flash +pentax k-5 Purusam Pentax K-5 2 03-12-2011 05:02 PM
Will a YN-560 Flash Blow Up My K-x? DaveHolmes Troubleshooting and Beginner Help 18 12-02-2010 10:52 AM
All times are GMT -7. The time now is 12:38 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
