10-21-2011, 10:51 AM   #1
Contrast, Saturation, Sharpness
I've noticed in the EXIF data of many photos on Flickr that the Contrast, Saturation and Sharpness are often at high, hard, etc.
Is this something you often change in-camera? I've been under the impression that, if shooting raw, it's better to make these adjustments in post.
Would really appreciate your thoughts on this.
Somewhat related: what is your default Image Finishing Tone (i.e. bright, natural, portrait, etc.) and why? Do you leave it on the camera's default of "bright" unless the specific scene calls for something different?
10-21-2011, 11:19 AM   #2
RioRico's Avatar
Yes, these settings can be changed in-camera. Look in your manual under Custom Image. On my K20D, I press the Function button, then the OK button, and that takes me to the Portrait-Landscape-Vivid-B&W settings, where I can change contrast-sharpness-saturation-hue for each. I usually use either Vivid or B&W. Depending on the quality of light, I may change their Contrast settings.
But I also shoot RAW-only. These settings carry into the RAW developer as defaults that I tweak as needed, so I'm not stuck with JPGs with those settings locked-down. If you shoot JPG-only, you should pay close attention to the settings, adjusting them till you get what you like. If you shoot RAW, then don't sweat it.
10-21-2011, 01:10 PM   #3
Thanks, I guess that's what I was getting at: whether or not I need to worry about altering contrast, sharpness, etc. in-camera if I'm shooting in raw.
I almost always adjust contrast, saturation, etc. in post but my EXIF data always stays as "normal", so my assumption is people are making these changes in-camera.
I know how to make the changes in-camera. Just not sure if it's "better" to adjust them later. From what I understand, for example with mono-chrome, to shoot the image in raw-color and make the b&w conversion later in post processing.
10-21-2011, 02:19 PM   #4
RioRico's Avatar
QuoteOriginally posted by Antifreez Quote
I'll often shoot with Custom Image set to B&W, and some filtering and qualities set. Then in RAW development, I'll try different filtration and qualities, and maybe generate color images too, all of which will get different treatment in PP. They're all just grist for the mill, raw materials to feed to the shooping machine.
camera, contrast, default, dslr, k-5, k-5 ii, k-5 iis, k5, pentax k-5, saturation, sharpness
K5 - How do I access "Custom Image" to change sharpness/saturation/contrast, etc ? Feudal1 Troubleshooting and Beginner Help 3 11-03-2010 06:38 AM
what do you set the sharpness and saturation to? Deiberson Pentax DSLR Discussion 13 03-07-2010 07:11 AM
Contrast and saturation question yeatzee Digital Processing, Software, and Printing 5 01-12-2010 01:46 PM
Do you customize the Sharpness, Contrast and Saturation settings on your DSLR? lastdodobird Pentax DSLR Discussion 12 01-30-2008 07:41 AM
More K10D saturation/contrast matrices mattdm Pentax DSLR Discussion 3 11-16-2007 10:59 AM
All times are GMT -7. The time now is 09:59 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
