Originally posted by Schraubstock Hi
I may just point out when the word sticky is mentioned in conjunction with film type protectors, there is actually no glue or adhesive involved.
The side of the foil that faces the LCD is specially treated and adheres to the LCD surface by surface tension only. In fact you can carefully peel off the foil without kinking it if you are not happy with your installation. If some dirt or fluff is stuck, wash it with warm water and half a drop of detergent, rinse it carefully, flick off the excess water and dry with a hairdryer. Don't use a towel to dry as fluff will stick to it. Now you are ready to re-install.
Greetings
That's how many of them work, but the ACMAXX actually does use a sticky border (sticky part does not touch LCD screen). It is fairly easy to remove, however, and will not leave residue. It is thick and hard, not like the flexible ones that just adhere by themselves.
