10-28-2011, 04:47 PM   #1
brosen's Avatar
Pentax Battery D-LI90 Genuine or Replica ?
Hi, I just purchased a couple of new batteries in Amazon.com as "Brand New" BULK packaging from a third party vendor, and they are not like the battery that came with the K-5, I have attached their pictures. Do you think they are "Genuine" Pentax D-LI90 or they are just a replica ?, one of them seem to be very old as well, 2010, thanks
PENTAX K-5  Photo
PENTAX K-5  Photo
10-28-2011, 05:07 PM   #2
Not a K5 user but if it works and wasn't too pricey then I wouldn't be too concerned. There are both obvious and more minute differences between the batteries though. For instance the top battery's lower/2nd text box looks to be printed at a very slight angle but this could just be a simple QA(quality assurance) hiccup? Also, you should try testing the battery with a multimeter set to measure voltage and if the voltages match the numbers then it should be ok...but these are just simple thoughts/observations. As for the 201010 I think that would mean october (10th month) 2010 which isn't that old...but everyone has a different measurement of old.
10-28-2011, 05:09 PM   #3
hcc
hcc's Avatar
The pictures are identical to my D-LI90 battery, but for the lower text being in Chinese. The upper text is identical letter to letter, incl. engravings.
Based upon your pictures, it is impossible to say more ....
Hope that the comment may help.
(I have a K-7 which uses the same D-LI90 battery, and I just pulled out mine to check,)
10-28-2011, 05:21 PM   #4
If it works I'd not be worried. As an example I recently went through this exercise getting new batteries for my Panasonic. From camera stores ( as expected) between $48-$62. From a specialist battery store $30 (not too bad), but from ebay as alike battery with same warranty (12months) and more capacity then either store option and only $7.00 including postage. Sure the battery was probably a knock off and it came from China but if you were to buy the 'real deal' for a much higher price it's still just as likely to have been made in China anyway with no advantage of any longer warranty.
10-28-2011, 05:31 PM   #5
Hi,
hard to say, they looks almost correct but a little funny with the international english upper Label and the national japanese lower.
My Originals here in Germany are all with englisch Labels both. May be, that these are from a original, but wrong labeled Lot, with different language stickers, witch couldn't selled in normal way.
Related on my Batterys, I would say, that the 2010 Battery is the newer one. All my older ones, buyed in 2009 and early 2010 are without Date, only the new one from 2011 has. But maybe, that changed again.
But it's realy hard to say, specially from a picture, they are "Genuine", but if the price is "nice", so don't worry.
10-28-2011, 06:25 PM   #6
brosen's Avatar
I just tried to charge one of the batteries and the charge light is blinking green ?, does it means the battery is dead ?, thanks
10-28-2011, 06:31 PM   #7
I think the blinking light means the battery is charging. When I charge my 4 AA eneloops for my Kx the green light blinks slower and slower until it stays solid green, meaning the batteries are charged.
10-28-2011, 06:56 PM   #8
wlachan's Avatar
I think it's best to contact Pentax directly for verification. There are some very good fakes which are hard to detect, and "bulk" packaging sounds suspicious. Non-oem batteries usually depreciate faster and one can never ignore the danger of counterfeit li-ion batteries which might be more prone to blow due to improper circuitry.
10-28-2011, 07:11 PM   #9
When I get great deals from unusual sources on brand batteries and flash memory (especially SanDisk) I send an email to manufacturer's tech support with a detailed pic showing the label and any numbers. They recognize originals versus fakes and should send you a nice email letting you know to. Good luck.
10-28-2011, 07:14 PM   #10
Those look like the same battery to me!
10-28-2011, 08:51 PM   #11
SpecialK's Avatar
Picking nits...
Neither one is grammatically correct in the "Japan , Pack" (extra space) and "Japan,Pack" (no space) instance.
Batteries are an item with some of the most variable labeling.
10-28-2011, 08:53 PM   #12
I managed 1300 shots in DNG off my Pentax battery but only 500-600 shots off ACME battery after first full charge.
Obviously different batteries differ in capacity depending on various factors. Is there a significant difference between the number of shots you manage out of these 2 batteries?
10-28-2011, 08:55 PM   #13
brosen's Avatar
I've not tried the batteries, I just got them today, and I paid almost the same price you pay for genuine batteries so I am returning them to the seller and buying new ones at Adorama or B&H.
10-29-2011, 02:49 AM   #14
Hi
The battery that was packed in the box when I purchased my K-5 in Feb this year looks identical to the one in your first picture. The only diff is the date label which reads "201012"
Relax and be happy
Greetings
12-01-2011, 03:26 PM   #15
Docrwm's Avatar
Sorry I'm late to the party but I was researching D-Li90's and ran across this thread. The other issue no one addressed is that while Li batteries are superior because they have no memory effect they do have a limited lifespan of ~4 years as memory serves. So, buying older batteries off the shelf means they will have a shorter useful life.
battery, camera, d-li90, dslr, k-5, k-5 ii, k-5 iis, k5, pentax, pentax k-5, replica
For Sale - Sold: K-5/K-7 Grip and D-LI90 Battery jgmankos Sold Items 9 10-22-2011 12:55 PM
D-LI90 Battery care? mmrempen Pentax DSLR Discussion 4 09-26-2011 03:13 PM
For Sale - Sold: D-BG4 Battery grip for K-5/K-7 + D-LI90 battery (CONUS) acrollet Sold Items 2 01-10-2011 07:19 AM
Best price for K7 battery D-LI90?? OrenMc Pentax Camera and Field Accessories 3 11-06-2009 03:29 PM
All times are GMT -7. The time now is 12:06 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
