10-31-2011, 06:16 AM   #1
brosen's Avatar
K1000 - Mold inside the Viewfinder
I just purchased a brand new K1000 and it has something weird inside the viewfinder, do you know what is it ?, is it easy to clean or remove ?, I am pointing the camera to a white board. See the attached pictures, thanks
10-31-2011, 06:46 AM   #2
klh
klh's Avatar
Looks like degrading light seals. I've seen the same thing in an old K1000. The black pads get gummy and flake apart.
Should not be hard to clean, but you will need to replace the seals. That's the hard part.
10-31-2011, 06:47 AM   #3
brosen's Avatar
Please could you elaborate a little bit more, I did not understand, is this something easy to fix or repair ?
10-31-2011, 06:59 AM   #4
klh
klh's Avatar
Take a look inside the front of the camera. You should see some black foam rubber pads on the top by the focus screen. These pad the mirror when it flips up, but also prevents light from going around it and ruining your photo. My guess is these pads have gotten old and are falling apart.
Cleaning up the debris should not be too difficult, but it won't fix the real problem.
You can buy replacement light seal kits. I've never done a rebuild, but many others here have. A good place to start would be to look at this website.
www.pentaxs.com
10-31-2011, 01:42 PM   #5
PALADIN85020's Avatar
Looks like the old Halloween zombie is trying to get out of the case. Wave a crucifix over it.
John
10-31-2011, 02:35 PM   #6
gofour3's Avatar
One of my K1000's had the same issue. I sent it to Eric for a CLA and he had to remove the mirror cage to clean out the debris. All is well after it came back. Phil.
camera, dslr, k-5, k-5 ii, k-5 iis, k1000, k5, pentax k-5, viewfinder
Is this Mold? GregK8 Pentax SLR Lens Discussion 6 04-03-2010 09:47 PM
Getting "inside" the K2 viewfinder? Normpixel Pentax Film SLR Discussion 15 01-17-2010 02:08 PM
k1000 mold or string in prism lokerd Pentax Film SLR Discussion 5 09-03-2009 01:54 PM
K1000 Viewfinder Diopter k0og Pentax Film SLR Discussion 10 04-22-2009 07:34 AM
Is there a brightness switch inside the viewfinder? Sitting Bull Troubleshooting and Beginner Help 3 02-27-2009 05:30 PM
All times are GMT -7. The time now is 05:15 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
