10-31-2011, 10:45 PM   #1
AOShep's Avatar
Continuous frame shooting
I noticed that when shooting in continuous frame multiple shooting, the images don't always get recorded to the card in the right order. After shooting a few soccer matches I found that some of my shots were obviously not in file name numerical order. At first I thought it was just my imagination, but I have several sequences that recorded out of order. Is this a buffering problem or is my card too slow to record 7fps even if it was only 2 or 3 frames? Using a class 6 Transcend 16GB card.
11-01-2011, 12:14 AM   #2
hcc
hcc's Avatar
First time I hear about this type of pb although I do myself a lot of continuous shooting. Do you shoot RAW or JPEG?
Further, was your card full or near full?
In any case, I suggest to upgrade to a class 10 card as a fast card is definitely an advantage.
Food for thoughts..
11-01-2011, 03:03 AM   #3
RonHendriks1966's Avatar
I did see that ones before too. Never put attention in it my self.
11-01-2011, 11:54 PM   #4
AOShep's Avatar
I normally shoot RAW, but in this case I was shooting JPG so it wouldn't take so much time post processing 2,000 images of soccer matches and activities. I'll have to go back to other events that I did shoot RAW and see if I can verify any order switching. The card still had lots of room so it wasn't running low on space and I always performed format after off-loading the images.
I did get burned on another issue by not shooting RAW. After shooting a night match under the lights I forgot to change my WB back to daylight the next day. It's almost impossible to correct the WB on JPG but a snap with RAW. I saved some time in PP on one day and lost it all the next.
11-02-2011, 02:33 AM   #5
dosdan's Avatar
QuoteOriginally posted by AOShep Quote
If I undertand you correctly, in a sequence of 3 original shots:
shot1
shot2
shot3
and assuming your camera was set to calling them Pentaxnnn.JPG, then for example:
Pentax721.JPG=shot1
Pentax722.JPG=shot3
Pentax723.JPG=shot2
So if you sort them by filename they are out of sequence, but if your image viewer sorts them by EXIF Date/Time they're fine?
If so, I'd set your file viewer to sort by EXIF Date/Time or if it really bugs you, do a batch rename. I'd use the freeware image viewer/processer XnView for this. Say you first sort 300 raw images by EXIF Date. The earliest is PENTAX0721.RAW, Then batch rename them. In XnView's Batch Rename, you can sort & rename in one go (using my own files as an example):
Actually, if it was up to me, I'd do the raw processing in EXIF Date/Time order, delete the failed shots and finally batch rename them at the end, so the sequence numbering was contiguous.
Dan.
camera, card, dslr, frame, k-5, k-5 ii, k-5 iis, k5, pentax k-5
Continuous Shooting frame rate ilt Pentax K-r 6 05-20-2011 04:07 AM
Single Frame Shooting Vs Continuous Drive Mode Verglace Troubleshooting and Beginner Help 5 03-05-2011 08:19 AM
K-7, continuous shooting, EXIF data, ... hcc Pentax DSLR Discussion 7 06-17-2010 08:01 PM
K-7 continuous shooting problem Rusty Rat Pentax DSLR Discussion 9 04-25-2010 08:11 AM
K-x continuous shooting problem. JP_Seattle Pentax DSLR Discussion 10 01-20-2010 11:23 AM
All times are GMT -7. The time now is 08:22 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
