Originally posted by kent Try to set Look Profile to Event. Even Product profile is more saturated than both LR and PS
Yes that worked(perfect).
With this, I was able to look over the differences between ACR and Bibble Pro and found that that were limited to profiling(basic settings). And so to test this theory, I adjusted ACR to match and created a new profile called: ACR_Event.xmp (see attached file).
Anyways, if you're interested, you can download the profile and give it a try. I'm not 100% certain but it might work in LR too. However, the differences are so small that I think anyone could easilly adjust and create their own profile in LR also. So there's that option as well.
Having said that, I've been looking over Bibbles demosaic output to compare with ACR and I think they are both using the same engine(identical artifacts etc):
As for ACR and Lightroom, I think it's a shame that Adobe doesn't take the time to code the camera profiles into the software. Especially knowing they do it for Nikon and Canon. Having said that, I guess it's not so bad considering that most profiles can be easily created and replicated too. - Perhaps there should be a repository on Pentax Forums for such things.
Anyways, I'm going to give Raw Therapee a look and see how it measures up against Bibble on the profile and demosaic side of things. Who knows... maybe the free software will end-up being the better solution
