Originally posted by jazon How do you get the 1/180? The camera settings go 1/125 1/160 then 1/200. Is this is down to the lens I am using (DA 18-55mm F.35-5.8) Also it jumps from 1/320 to 1/400. I have looked through the settings to make fine adjustments to get the 1/180 and 1/340 but no luck. It is probably insignificant but I am just wondering.
Jazon, I hope you had some success in your last outing since there are so many good suggestions from your fellow forum members. 1/180 is the max sync speed for the built-in flash on the k-5, and that is the most (fastest shutter setting) you get as soon as you pop the flash up. At some point, you may want to explore and invest in an external flash; and that's where your creativity begins (of course YMMV).
One of the important criteria
for me in event photography is to capture the 'mood' not just the scene. The external PTTL flash with swivel head will provides a rich set of features that if you use the flash properly, it may help in a lot of situations where non-flash shots with only the natural lighting from the environment may not give you that result. Here is an example of a shot I took at a party where the harsh tungsten (only) light is coming directly from the top and the rest of the floor is very dark:
