11-27-2011, 03:21 PM   #1
K5 Shutter release problem
Hi Guys,
Had this problem yesterday and wanted to run it by you all to see if there is an obvious fix/issue?!
Basically, when I pressed the shutter button, it made a sound like a slow muted shutter sound but did not take a pic. the battery indicator then said empty, the LCD said Battery Depleted, then the camera shut down.
I tried this several times with fully charged batts.
The camera would only state the battery was depleted after pressing the shutter release. Otherwise the batt indicator would show as full.
After trying everything with the settings, including restoring default settings and 'hard resets', I found that by pressing the live view button twice (first press showed a completely black screen) resolved the problem and now all is fine.
Anyone have some advice on what I should do?
Thanks
Paul
11-27-2011, 03:41 PM   #2
aleonx3's Avatar
It is difficult to judge based on what you described, do you have another freshly charged battery to try?
11-27-2011, 04:39 PM   #3
RonHendriks1966's Avatar
QuoteOriginally posted by 10speeduk Quote
Well it is electronics, so something was off. If it is fine, I suggest just to use the camera. There is no reason to send it in for repair, since the problem is gone. A repaircentre can not reproduce such a thing and thus can't do anything for you. If it doesn't come back, there is no problem. If it does come back see if you can solve the problem again with the LV button. If it happens another time, just send it in for repair.
11-27-2011, 04:57 PM   #4
Yea, the K-5 has brain farts some times. Just keep on trucking with it.
11-28-2011, 12:55 PM   #5
cool, will carry on. My brain stops most days....!
battery, button, camera, dslr, k-5, k-5 ii, k-5 iis, k5, pentax k-5, release, settings, shutter
Shutter release problem with my K7 Jon in SC Pentax DSLR Discussion 6 08-28-2010 12:14 PM
K-x Shutter release? Pantingfish Pentax DSLR Discussion 9 04-23-2010 09:17 PM
problem with spotmatic sp shutter release button cvsuave Pentax Film SLR Discussion 3 04-21-2009 04:41 AM
Remote shutter release problem slowpez Pentax Camera and Field Accessories 10 07-29-2008 07:17 AM
Super Program problem with film advance and shutter release Laurie60014 Pentax Film SLR Discussion 6 07-18-2008 09:00 PM
All times are GMT -7. The time now is 07:32 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
