11-28-2011, 09:11 PM   #1
liukaitc's Avatar
why the aperture changes for each shot when I use exposure bracketing
Hi..when I use exposure bracketing 3images, the aperture changes for each of the shot.
for example 0.5s f10 ,1/4s f14, 1s f7.1
I only want change shutter speed..do not want change aperture...
and I do not see any setting related to this issue
11-28-2011, 09:39 PM   #2
twitch's Avatar
QuoteOriginally posted by liukaitc Quote
Bracket in Av mode and it wont change. I recall this happening to me in TAv mode, and it will definitly happen in Tv mode.
11-28-2011, 09:45 PM   #3
liukaitc's Avatar
I used m mode......
let me try av then....
11-28-2011, 09:48 PM   #4
liukaitc's Avatar
wow..u r right..in av mode..it won't change..thanks..problem solved
11-28-2011, 10:20 PM   #5
sterretje's Avatar
You can play with the program line setting; might do the trick in M mode
11-29-2011, 02:34 PM - 1 Like   #6
Trig's Avatar
Just a heads up (in case you don't set a custom or preset white balance or set it in post when you shoot in RAW), the white balance will also change (within the brackets) if you use auto bracketing. So if you use auto bracketing, keep an eye on the white balance values/temperatures on the individual exposures. Of course this only really applies if you are using different exposures together or are making a HDR of the exposures.
aperture, aperture changes, camera, change, changes, dslr, exposure, k-5, k-5 ii, k-5 iis, k5, pentax k-5, shot
HDR/Multi-exposure/Exposure Bracketing sany Troubleshooting and Beginner Help 4 04-24-2011 08:52 PM
Exposure bracketing with the K-x ptx101 Troubleshooting and Beginner Help 6 04-05-2011 08:17 PM
Anyone with a k7 please help (exposure bracketing) pixelhunter Troubleshooting and Beginner Help 11 02-04-2011 11:06 AM
Exposure Bracketing iman1981 Troubleshooting and Beginner Help 8 05-24-2010 01:21 AM
Exposure Bracketing on the K-x noahpurdy Troubleshooting and Beginner Help 7 12-26-2009 10:28 PM
All times are GMT -7. The time now is 04:54 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
