Originally posted by ross I turn the aperature ring until the center looks sharp then I check the distance on the lens but still no luck.
First I assume you mean the focusing ring, not the aperture ring, right? Do you have the lens in the 'A' position or are you setting the aperture manually? Either way, what aperture are you using?
To test, set up on a tripod and focus on something flat with detail, like a brick wall. You should be able to get a good focus at any aperture since there is no depth of field to matter. Try one shot using the viewfinder and another using live view, compare the results.
Remember, if you are using the lens wide open the depth of field will be very small. Something in your photo is probably in focus but I cannot tell, maybe the yellowish shrub? At f/2 the depth of field at 10 feet is about 1 foot. At 20 feet it is about 4 feet. Hard to assess this without knowing the aperture used.
