11-29-2011, 01:38 PM   #1
Mychael's Avatar
Is this a dead/hot pixel ?
I was just enlarging up a photo on the computer to check some detail and noticed this square spot in a cloudy sky. Enlarged it's perfectly square so I'm assuming pixel but not sure. It shows up as the smallest dot on the normal sized image.
11-29-2011, 01:52 PM   #2
RioRico's Avatar
Could be. Run the PIXEL MAPPING tool -- it's in the [SetUp] menu on my K20D. If the pixel is dead or hot, the tool will heal it.
11-29-2011, 01:52 PM   #3
Looks like dust.
11-29-2011, 01:56 PM   #4
Mychael's Avatar
QuoteOriginally posted by Tony3d Quote
Looks like dust.
Would dust have such a square shape though.?
11-29-2011, 02:00 PM   #5
Run the pixel remapping. That will tell you.
11-29-2011, 02:02 PM   #6
Looks like dust.
Agreed - it isn't really square, only enlarged to such a degree it begins to have pixeled edges. A hot pixel usually shows up as white after a longer exposure, and a dead pixel would only be 1 pixel, or a random cluster. This is somewhat circular and not even, lending itself to being dust. How much is this enlarged?
11-29-2011, 02:19 PM   #7
Swapnil's Avatar
To me it looks like a dust,
Run "Dust Alert", That will definitely tell you if that's a dust spot.
11-29-2011, 02:44 PM   #8
Mychael's Avatar
Enlarged a lot, though having said that I ran a pixel map then took a photo of a blank wall, enlarged that and everything was clear again. Anyway it's not there atm whicj is the main thing. Thank's for looking.
camera, dslr, k-5, k-5 ii, k-5 iis, k5, pentax k-5, pixel, square
New K-r with Dead LCD Pixel geekkt Pentax K-r 6 11-27-2011 10:59 PM
dead pixel on kx mustangjoey Pentax DSLR Discussion 7 01-13-2011 11:36 AM
Dead pixel on the Sensor? zheric Pentax DSLR Discussion 8 01-11-2011 10:14 AM
What counts as a dead pixel? KansasHorizons.com Pentax DSLR Discussion 7 03-11-2010 01:27 PM
K10D back from dead/hot pixel repair pentaxbling Pentax DSLR Discussion 6 10-08-2007 05:31 PM
All times are GMT -7. The time now is 02:40 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
