12-03-2011, 11:50 AM   #1
Focusing issues on K5
i just bought a K5 and went out today to shoot some landscape. On both of lenses used, the camera would have a hard time focusing on distant objects. It would not lock focus and i'd have to focus on something closer. I have camera set to not allow shutter release unless focus is locked. I went back and tried the same lenses on my K20d with no issues. I've read about low light focus problems with the K5, but this was in bright daylight. Can anyone suggest what I might do?
Thanks,
Curt
12-03-2011, 12:43 PM   #2
You'll want to go in to the AF adjustment menu (in the custom functions area) and adjust the focus for those lenses. This happens quite frequently with older screwdrive lenses for me, but not just on the K-5. In my case, an adjustment of between +3 and +5 usually fixes the problem. Lenses that I've had trouble with included the FA 20-35mm F4, FA 31mm, and FA* 85mm (surprisingly).
12-03-2011, 12:44 PM   #3
Try resetting all custom settings to default.
12-03-2011, 12:48 PM   #4
reeftool's Avatar
Is the focus point in the place where you want it? Was the subject in the distance something the camera couldn't lock on? I have had issues with my K10D not locking focus at infinity when the focus point was the sky. It only happens sometimes but when it does, the lens hunts back and forth to the extremes of the focus range. My K5 is new also but I have had no focus issues to speak of in the little time I have spent with it.
12-03-2011, 01:12 PM   #5
k5 focusing
Just to clarify, these are older inexpensive lenses that I've used on both k10 and K20. The lenses are Sigma 28-105 and Tamron 28-200. They both have worked fine on my older Pentax DSLRs.
I guess I'll try these adjustments. .
12-03-2011, 01:14 PM   #6
Forgot to add that I was focusing on things that the camera could focus on such as a door on a distant building, trees on the horizon, etc.
12-03-2011, 01:34 PM   #7
jolepp's Avatar
Another thing worth trying might be updating the firmware to the greatest and latest. Going from 1.03 to 1.11 seemed to make a difference for me as far as AF goes: the camera took a warranty repair trip for more backfocus in daylight with the DAL 55-300 than could be compensated with the AF fine adjustment and the DA 100 macro at +10, it came back with a note explaining that they had updated the firmware (+ a cryptic mention of adjusting "105 circuit" (?)) and that they had tested AF and found it "fully accurate". After the service trip (and much testing and tinkering with the AF fine adjustment ) +4 would seem to be the best setting for both the DAL 55-300 and the DA 100.
camera, dslr, focus, issues, k-5, k-5 ii, k-5 iis, k5, lenses, pentax k-5
Here is a solution for all focusing issues. mrjamesabels Pentax DSLR Discussion 6 07-26-2011 04:04 PM
K7 focusing issues. aragondina Troubleshooting and Beginner Help 8 05-26-2011 10:12 AM
Focusing issues bigonroad Pentax SLR Lens Discussion 10 01-08-2011 11:19 AM
K-7 back-focusing, and lens issues BigMackCam Pentax SLR Lens Discussion 13 03-24-2010 05:26 PM
M42 Supertak 55 f1.8 focusing issues ismaelg Pentax SLR Lens Discussion 3 12-11-2009 04:46 PM
All times are GMT -7. The time now is 06:38 AM. | See also: NikonForums.com, part of our network of photo forums!
