Originally posted by mtansley Nice idea but I don't own a telescope. I'm just trying out the GPS unit on the camera.
That's why I'm trying to find a 'low cost' way of targeting the camera.
However, what sort of simple mounts are there that let you connect the camera on top of the telescope body?
I've been pretty lucky, the targets I've attempted to shoot are easy enough to bring into view (even with a 500mm).
Actually any inexpensive scope would do the trick I suppose, check swap meets/yard sales even.
As for simple mounts, I thought I saw a generic mount but all I can find are ones that are for through the eyepiece shots or scope specific mounts for piggybacking.
That said one could adapt a tube ring with a 1/4-20 screw but simpler and cheaper than that, I'd use some plumber's tape (even better a hose clamp) with a 1/4-20 bolt through the strap. Attach the camera first to the strap, then wrap the plumber's tape around the scope and bolt the ends to snug it up on the scope tube.
