12-06-2011, 06:51 PM   #1
eccs19's Avatar
Question about K5 Lockups
So I know that some users have issues with their K5 locking up, and to fix it, you just pull out the battery and pop it back in. Not a deal breaker for me by any stretch of the imagination. My main question is.... If your using a grip, and your pulling the power from the grip battery, and it locks up, will just pulling the grip battery do the job, or does the grip need to be removed, and also pull the battery from the body? My K7 I've got it to use the grip by default, and if I get a K5, I'd set it the same, but not sure if this would work in this case to reset it.
12-06-2011, 08:09 PM   #2
SpecialK's Avatar
If you have the battery management set to whichever battery has the most power, then likely you will have to remove both of them. I've had freezes in the distant past but I don't use a grip on the K5. Seems easy enough to figure out if/when you have that issue.
12-06-2011, 08:16 PM   #3
I've had to remove both unfortunately Has only happened once, though!
12-07-2011, 06:32 AM   #4
geezer52's Avatar
While I've had one or two lockups where R&Ring the battery resolved things, in my more recent experience that has not worked. And I've gotten a "battery depleted" message on the lcd screen even tho the battery was freshly charged. In my case a small rap of the K5 with the palm of my hand got things working again. Another poster said pressing the live view button twice worked for him. If R&Ring the battery works I wouldn't get too concerned, but if the second case becomes a pattern I would consider sending it in.
12-07-2011, 10:36 AM   #5
This should not be happening. Send the camera in to Pentax. There's either something up with the actual circuitry or with the logic that governs battery use.
07-17-2012, 09:30 PM   #6
I called my Pentax rep and he says he's never heard of this problem.. he's been working for them for a year. He offered me another battery to try. My also camera got rather hot yesterday and after using two K-5's for a year and never feeling anything like that I'm more than a little pissed off.
Dord anyone have an solution to the Lock-up problem?
07-18-2012, 12:52 PM   #7
sent my k5 in for what seems to be stain , also told them about lock up it only happened once but thats enough c.r.i.s. got her today will see what happens. quite a shame as i got her new as could be and was very happy a42xxxxxxser#. lost with out her
07-19-2012, 12:13 AM   #8
Well, I've just found something interesting regarding the locks : sometimes it's just a slow SD card!
One day I've shot a long movie clip (2-3 minutes, don't remember) without paying attention on the SD card used (was an old PNY 8Go class 4)...
Then as soon as I stopped the recording, I switched to Av mode to grab a snap of my daugther. The camera locked absolutely solid! Power off, LV, shutter, wheels, nothing worked and the rear screen was locked in Liveview.
I then noticed that the writing LED was lit. I let the camera alone for some time, and it became responsive again after a good 2 minutes.
So I did some tests, and I can now duplicate this particular freezing at will... With a fast card you won't have it, but with slow ones, recording a lengthly movie then switching to still mode will "lock" the camera until the buffer is cleared.
07-19-2012, 12:32 AM   #9
I haven't had any lock-ups today but I will say that my card is exactly the same as it was yesterday. I use two 16GB 30mb/sec cards for my K-5 and a 32GB class10 for my D800E. I will try my faster card in the camera tomorrow and see what happens. This might explain why this issue appears more when shooting in continuous burst modes.
Thanks for the info.
battery, camera, dslr, grip, k-5, k-5 ii, k-5 iis, k5, pentax k-5, question
CS 4 Question THAN THE SWORD Digital Processing, Software, and Printing 3 03-08-2010 09:40 PM
Question: which one should I let go? senree Pentax SLR Lens Discussion 12 02-16-2010 12:11 PM
question Danny Delcambre Troubleshooting and Beginner Help 10 01-02-2010 02:12 PM
A Question about K-7 oxidized Troubleshooting and Beginner Help 9 12-17-2009 09:56 AM
An Answer to a question and a question. granitic Pentax DSLR Discussion 5 02-23-2007 09:28 AM
All times are GMT -7. The time now is 03:05 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
