12-07-2011, 03:36 AM   #1
dosdan's Avatar
Using a M lens in LV on the K-5
I hardly used LV on the K20D. Since I've got a few M lenses, I decided to see about using 10x zoom-in during LV on the K-5 to check focus accuracy.
With FW 1.11 I noticed I got what I assume to be lockups (requiring pulling out the battery) using a M lens in LV when I pressed the green button to stop down the lens - it seemed to leave it stopped down. This happened 3 times in a row.
Later when I tried it again, the green button worked as expected and set the shutter speed in LV and, after stop-down, opened up the aperture fully again, with LV still working normally.
Has anyone else experienced "lockups" doing this procedure, and if so, what is the sequence of operations that triggers it?
Dan.
12-07-2011, 08:27 AM   #2
I experienced the lockups as well, but I do not use M lenses very frequently anyway. Still I'm interested whether this is a common issue of all K-5's or only some are affected. I'm sorry I cannot contribute with more knowledge on reproducability of that issue.
12-07-2011, 08:44 AM   #3
sterretje's Avatar
Normally I don't use LV; just tried it and it does not lock up. I haven't had any lockups (yet) anyway. FW is 1.11
12-07-2011, 11:35 AM   #4
dosdan's Avatar
QuoteOriginally posted by sterretje Quote
Did you try using the Info button to zoom in?
I think using LV with 6x , 8x or 10x when using a MF lens on a tripod for a static subject will help to get better focus accuracy than a 3rd-party focusing screen.
Dan
12-07-2011, 11:43 AM   #5
sterretje's Avatar
OOPS, missed that
Will try to test that tomorrow; currently on charge
12-08-2011, 04:03 AM   #6
sterretje's Avatar
Hmm... In LV mode with magnification (8x), the green button does not do anything that I can see. At 1x magnification, it does the metering.
And still no lockups
12-08-2011, 07:21 PM - 1 Like   #7
drougge's Avatar
I would guess it was fairly dark when it locked up. See this thread.
12-08-2011, 08:11 PM   #8
dosdan's Avatar
QuoteOriginally posted by drougge Quote
Yes, it was. Now that I know what triggers it, I can avoid this situation. Looks like it will be fixed in a future firmware update.
Thanks for clearing that up.
Dan.
12-08-2011, 09:59 PM   #9
sterretje's Avatar
What now leaves me with the question why mine does not meter when enlarging the view?
12-08-2011, 10:27 PM   #10
dosdan's Avatar
Mine only meters on 1x too. It's not a great limitation:
1. Set exposure first
2. Then zoom to get a sharp focus.
3. Then press the shutter release button
Dan.
12-08-2011, 11:34 PM   #11
sterretje's Avatar
Thanks, I thought you metered while the image was enlarged.
I was not specifically worried about it, but just curious
01-12-2012, 02:59 AM   #12
dosdan's Avatar
I've updated to Firmware 1.12 and, although undocumented, it does fix the green button LL lockup problem, described here
https://www.pentaxforums.com/forums/pentax-k-5-forum/165486-need-your-help-is...g-problem.html
Dan
button, camera, dslr, k-5, k-5 ii, k-5 iis, k5, lens, lv, pentax k-5
Keep K-x buy premium lens, get K-r and get good lens, get the K-7 w/ lens or K-5? crossover37 Pentax DSLR Discussion 19 02-06-2011 10:38 PM
All times are GMT -7. The time now is 05:48 AM. | See also: NikonForums.com, part of our network of photo forums!
