12-13-2011, 08:04 PM   #1
Screen Protector for K-5
Wanted to take advantage of the 25% discount & free shipping from BestSkinsEver and wasn't sure what the closest match for pre-cut skins would be.
Any idea? The S95 comes close but leaves a few mm short on the long side...
12-13-2011, 10:31 PM   #2
Fl_Gulfer's Avatar
SYSAN Hard type LCD screen protector for Pentax k5/k7 | eBay
12-14-2011, 07:44 AM   #3
Can you remove this one and reapply if needed?
If so how easy it is to remove? Do you need to apply heat to do so?
12-14-2011, 10:14 AM   #4
I bought a similar product from bodyguardz and used the one for a Canon Rebel EOS XSi. I'm pretty ocd about these things, and use this on a lot of stuff I have so I also cut out a piece and used it on the top lcd.
12-14-2011, 02:02 PM   #5
Fl_Gulfer's Avatar
5. High quality sticky material for no residuce when the protector is taken off
12-14-2011, 02:03 PM   #6
Fl_Gulfer's Avatar
I have one made by Armor ... (something or other). I just can remember the whole name.
12-14-2011, 04:46 PM   #7
SYSAN looks like ACMAXX LCD Armor protector, 2 screens protectors (rear and up ) but SYSAN is 0.8mm thick and the ACMAXX 1.2mm.
12-14-2011, 05:58 PM   #8
Try the SGP PENTAX K-5 Screen Protector Series. They give you two sets in case you mess up installing. Looks like Amazon is now the store front for the SGP.
camera, dslr, k-5, k-5 ii, k-5 iis, k5, pentax k-5, screen protector
LCD Screen Protector for K-5 apac Pentax K-5 & K-5 II 22 12-10-2011 02:18 PM
What lcd screen protector do you use? Balog Pentax K-5 & K-5 II 45 04-04-2011 10:07 PM
LCD screen protector Tony3d Pentax DSLR Discussion 9 10-26-2010 01:48 PM
ACMAXX Screen protector jules Pentax DSLR Discussion 6 08-06-2010 12:07 AM
Screen protector again - Canadian search jpzk Pentax Camera and Field Accessories 12 01-16-2010 11:45 AM
All times are GMT -7. The time now is 11:00 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
