01-04-2012, 12:18 PM   #16
ogl
ogl's Avatar
Sorry, I will make some tests soon...I was too busy.
01-04-2012, 02:17 PM   #17
dosdan's Avatar
QuoteOriginally posted by ogl Quote
If this is a raw processing bug, the way to confirm that would be to use another raw processor like DCU4, or probably better because it does no optimisations, RawTherapee.
As regards how ISO80 is achieved, I can't think of a reason why that would affect resolution. I speculate that the linearity of the sensel deteriorates near FWC. Nikon & Sony do not run it in this region. Pentax does, and compensates for this non-linearity in their processing. Hence they can push the FWC a little further.
Or maybe Pentax has mapped the gain of each sensel on each individual sensor and compensates for these PRNU irregularities. (Probably too expensive to do this though in a non-pro camera.) This would give less highlight noise at base ISO. Perhaps this would somehow allow a better FWC too.
Dan.
01-05-2012, 08:02 AM   #18
falconeye's Avatar
QuoteOriginally posted by dosdan Quote
Dan, interesting idea.
However, I'm not sure this is compatible with the part as Sony ships it. It delivers the raw image data in digital form and AFAIK all you can do is program a 4 bit digital amplification factor prior to ADC. All else is in-camera post-processing. The 4 bit factor means 1 ... 31 actually but I'm not sure it can go above 16.
So, it's the same game for everybody.
To avoid to expose near the FWC, you really have to underexpose. But this would be renormalized by DxO if the camera would do so. So, I'm rather sure that FWC is not involved in the Pentax ISO 80 (or 14+EV DR) conundrum.
01-06-2012, 06:43 AM   #19
ogl
ogl's Avatar
Hmmm...I've found today that my FA43 is unpredictable at K-5....Big problem with AF accurancy, not with sharpness. I will retest with FA77 or FA135. It's much better than FA43.
01-08-2012, 11:15 AM   #20
falconeye's Avatar
I would have guessed that you were aware that AF accuracy is the #1 issue to check with sharpness tests.
01-26-2012, 02:23 AM   #21
ogl
ogl's Avatar
No any difference with ISO80 and ISO100
01-26-2012, 02:35 AM   #22
Ash
Community Manager
Ash's Avatar
There is going to be very little discernible difference between 80 and 100. But there are early sources that note 80 performing very well in every aspect, particularly shadow detail. No issue with sharpness. Each camera may have its AF accuracy nuances but it's not an ISO 80 issue.
camera, dslr, filter, iso80, k-5, k-5 ii, k-5 iis, k5, pentax k-5, picture, sharpness
Who wants to see an ISO80 RAW file pushed +10 stops? JohnBee Digital Processing, Software, and Printing 14 11-09-2010 01:58 PM
K-5, ISO80 vs ISO6400 Early Case Study(JPG)... JohnBee Pentax K-5 67 10-18-2010 06:53 PM
K-5 ISO6400 vs ISO80 - Advanced NR Study... JohnBee Pentax K-5 12 10-17-2010 08:27 PM
Sharpness vs Fine Sharpness on K20D morfic Pentax DSLR Discussion 2 11-02-2008 10:13 AM
Fine sharpness and sharpness move together on K20D 1.01 morfic Pentax DSLR Discussion 2 07-11-2008 09:18 PM
All times are GMT -7. The time now is 08:55 AM. | See also: NikonForums.com, part of our network of photo forums!
