12-22-2011, 01:08 AM   #1
How to find out build date of K-5?
Hi folks! Recently bought the K-5 at Henry's here in Canada with the 5 year extended plan with the 18-135mm WR lens. The cost of all the gear really does add up quickly!
Thought I'd make my acquaintance by starting a thread regarding a somewhat irrelevant issue, that is, the build date of my camera. Anyone know of a way to find this info out? Considering that many complex electronics have the date stamped on the unit, it would have been "cool" in this case as well.
Now I have to research that sensor stain thing but it's probably not an issue because Henrys moves a lot of stock...
Thanks and caio!
12-22-2011, 01:14 AM   #2
See this thread:
https://www.pentaxforums.com/forums/pentax-k-5-forum/135973-where-do-i-find-build-date.html
See also the serial DB:
Pentax K-5 Serial Numbers - Pentax Serial Number Database - PentaxForums.com
12-22-2011, 01:42 AM   #3
Thanks for the info. I updated my firmware to 1.11 before I checked my manufacture date. I learned about Photome after the fact.
The date says Oct 24/2011. Is this date connected to the firmware date or is this the actual build date?
12-22-2011, 02:08 AM   #4
QuoteOriginally posted by jazzcat Quote
... firmware date or is this the actual build date
In PhotoMe if it says: Manufacturing Date it is Manufacturing date and that will not change if you load new FW. It will only change if a new Main Board is fitted as the manufacturing date is coded there.
Greetings
12-22-2011, 04:59 AM   #5
You can now confirm this date using our new online tool: Check Shutter Count & Camera Manufacture Date Online - EXIF Reader
12-22-2011, 08:41 AM   #6
aleonx3's Avatar
Welcome to the forum and congratulation on your purchase of the k-5. I got the k-5 from McBean (save a little more on taxes) earlier in the month. If you look at the k-5 serial number database, there is not a lot to worry about the stain issue as there was none reported recently. Also since you have purchased the 5-year warranty, you should be good. Meanwhile, enjoy your new toy. Here is the k-5 database link.
Pentax k-5 serial numbers
12-22-2011, 12:47 PM   #7
Thanks again guys for helping a newbie. Now I can go learn how to take pictures!
build, camera, date, dslr, issue, k-5, k-5 ii, k-5 iis, k5, pentax k-5
Where do I find the build-date? DogLover Pentax K-5 6 03-08-2011 01:59 AM
K-7 Build Date brosen Pentax DSLR Discussion 7 08-28-2010 07:31 AM
Lens build date brosen Pentax SLR Lens Discussion 1 08-28-2010 07:03 AM
PC Build? Fl_Gulfer General Talk 48 03-20-2010 09:06 PM
EXIF help (date created) vs. (date taken) dragonfly Digital Processing, Software, and Printing 3 09-12-2009 10:22 AM
All times are GMT -7. The time now is 09:18 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
