12-22-2011, 07:11 PM   #1
LightSpeed's Avatar
Need a quick answer to this. Pentax Asahi Takumar
Will this lens : Pentax Asahi Takumar 500mm f4
Work with the k5 mount?
I'm not sure what an m42 mount is either.
12-22-2011, 07:25 PM   #2
m42 is a screw-mount, and it will not work without an adapter. With an adapter (get the Pentax genuine one, not a cheap knockoff), it will work but only in manual mode -- no auto-aperture, no auto-focus.
12-22-2011, 07:26 PM   #3
jatrax's Avatar
M42 is an older mount used by Pentax and others. It is a physical mount only, no electrical contact. It was superseded by the k mount in 1975. It can be used on k mount cameras such as the k-5 with an adapter. It will be manual focus, manual aperture and you will need to use the green button stop down metering. I am not aware that there was ever an f/4 variant of this lens, f/4.5 is the fastest I know of and then also an f/5 version.
12-22-2011, 07:33 PM   #4
SteveM's Avatar
Takumar's are great lenses (except for the few that came in a K mount). Checkout the Takumar Club if you haven't already.
12-22-2011, 07:34 PM   #5
jatrax's Avatar
Amazingly there are currently 5 of these for sale on ebay at the moment. That just seems to be an unlikely number of a fairly rare lens to be on sale all at once.
12-22-2011, 07:44 PM   #6
Docrwm's Avatar
And the one marketed as a Nikon lens is $1999, which is about $1000 more than the next most expensive Takumar 500 listed right now
12-22-2011, 07:45 PM   #7
It will meter at whatever f stop you have the aperture ring set to. If you want a smaller aperture you can open the lens, focus, then step down by turning the aperture ring, then shutter release. The adapters are a simple ring that fits in the bayonet mount and has a female 42mm thread. Make sure you get a good one, some are too thick and prevent focussing to infinity.
Depending on what you use it for, it may be preferable to the K mount. The K mount requires the green button metering. The M42 meters in real time to the aperture setting.
12-22-2011, 07:51 PM   #8
LightSpeed's Avatar
That'll work.
Thanks guys
12-22-2011, 08:25 PM   #9
Here's how it's done:
https://www.pentaxforums.com/forums/pentax-lens-articles/110657-how-use-meter...k-x-k-7-a.html
Since it's a screwmount, you can even use them in Av mode, which is sort of convenient.
12-22-2011, 10:41 PM   #10
All about the M42 to K adapter...
asahi, camera, dslr, k-5, k-5 ii, k-5 iis, k5, pentax, pentax k-5, takumar
Quick Answer Needed! Telephoto... DRabbit Pentax SLR Lens Discussion 19 05-19-2011 08:12 PM
Leaving K-x in car, need quick answer please! kmets Troubleshooting and Beginner Help 31 08-13-2010 08:08 PM
TAKUMAR Asahi Pentax 800mm F4 C Mount janstew Pentax SLR Lens Discussion 4 06-27-2010 11:43 AM
For Sale - Sold: 400mm f5.6 Asahi Pentax Tele-Takumar M42 (US/CAN) photographics Sold Items 6 05-13-2010 10:44 AM
For Sale - Sold: Asahi Pentax Super Takumar 55mm f/1.8 neighhoma Sold Items 4 02-12-2010 06:06 AM
All times are GMT -7. The time now is 09:39 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
