12-23-2011, 10:22 PM   #1
*Rich's Avatar
How do I check which version firmware I have?
Just got a K-5 and I read everywhere to make sure you have the latest firmware version. How do I check which version the camera has?
Found nothing in the manual about it, nor can I find a menu item to choose like I can do with my Canon DSLR. Thanks.
12-23-2011, 10:30 PM - 1 Like   #2
Turn the camera off. Now press and hold the menu button while turning it on. It should say firmware version on the screen. I think you will find you do not have most recent version. Go here and follow directions carefully:
Downloads & Literature - PENTAX Imaging USA
12-24-2011, 09:25 PM   #3
*Rich's Avatar
Thanks. I had v 1.01, so I updated to v 1.11. It's odd that this procedure is not mentioned in the otherwise excellent Operating Manual for the K5.
A search on this forum also showed me how to check the manufacture date and frame count on my unit from the EXIF data of a JPEG shot. Great forum.
12-25-2011, 11:08 AM   #4
Firmware updates for most things seem to be a bit of a secret, probably because they are a dangerous procedure if you aren't too bright. But if you have a problem and go looking for support, you'll then be pointed to it, and if you send in the camera for service for any reason they automatically update you to the latest. But sometimes they do add new features, etc -- it is not all fixing problems. I guess they figure anyone "serious" will find it...
12-25-2011, 12:26 PM   #5
Bright people make silly mistakes - often.
12-25-2011, 01:57 PM   #6
QuoteOriginally posted by civiletti Quote
Errr...I meant "inexperienced".
12-30-2011, 01:20 AM   #7
trublubiker's Avatar
I picked up my new K5 yesterday.
Ran the checks and was a little bit surprised to see my camera, with a build date 2011:08:31, has firmware version 1.01.00.14, which I assume is the original version.
I'm guessing the original firmware version is embedded in the PCB.
camera, check, dslr, firmware, k-5, k-5 ii, k-5 iis, k5, pentax k-5, version
How to check Pentax's silent firmware version without update. mitkomk Pentax DSLR Discussion 15 12-16-2012 02:01 PM
Firmware Version? Franky2step Pentax K-5 2 08-29-2011 07:26 PM
Firmware check rr4562 Troubleshooting and Beginner Help 4 07-28-2011 08:10 AM
What firmware version does your K-5 have? adamfogerty Pentax K-5 5 10-21-2010 08:57 PM
K-7 Firmware Version ceojr Pentax DSLR Discussion 3 09-24-2010 05:10 AM
All times are GMT -7. The time now is 06:46 PM. | See also: NikonForums.com, part of our network of photo forums!
