12-26-2011, 10:17 AM   #1
wildboar's Avatar
Flash sync at 1/45, how to change?
The pop-up flash, and an external Metz, both sync to 1/45 in Av mode. How do I make it sync at 180 (or anything else) in Av mode?
12-26-2011, 10:20 AM   #2
demp10's Avatar
Unless you are trying to capture ambient light, there is no need to use use Av mode. Just switch to X-mode and the speed will be 1/180.
12-26-2011, 10:24 AM   #3
Ole
Ole's Avatar
QuoteOriginally posted by wildboar Quote
In Av mode the camera sets the shutter speed matching ambient light. If you want to control the shutter speed you should use Tv, M, TAv or X.
12-26-2011, 10:45 AM   #4
wildboar's Avatar
Demp, thanks for the reminder. That's what I needed. Its rare that I shoot with flash, and I knew there was an easy solution.
12-27-2011, 09:58 AM   #5
sterretje's Avatar
QuoteOriginally posted by Ole Quote
Also when using flash? My experience is that it chooses a speed based on the focal length. It seems very conservative with a rule of 2x focal length; for a FA31Ltd it's 1/60s and for a DFA100WR it's 1/180s; with the kit lens, it's variable depending on focal length and I'm not sure about the chosen speed (I think something like 1/30s to 1/90s).
12-27-2011, 03:35 PM   #6
wildboar's Avatar
sterretje, you are correct. In Av mode it chooses the sync speed based on lens focal length. I was using my DA21 when I asked the original question. When I use the DA70, flash sync is set to 125. Since I don't normally use flash with a wide-angle, it was odd (to me) seeing the 1/45 speed.
av, camera, dslr, flash, flash sync, k-5, k-5 ii, k-5 iis, k5, mode, pentax k-5, sync
sync off camera flash otisdeezer Troubleshooting and Beginner Help 11 12-26-2011 11:43 AM
K7 flash sync speed. eccs19 Pentax DSLR Discussion 7 02-20-2011 07:27 PM
Is Flash Sync Speed limited by the body or flash? Reportage Troubleshooting and Beginner Help 16 09-16-2010 06:18 AM
MX Flash Sync only on second port? Why? PNTXFTW12 Pentax Film SLR Discussion 3 06-28-2010 11:11 AM
X-sync and old flash Fallingwater Pentax DSLR Discussion 2 05-29-2010 03:11 AM
All times are GMT -7. The time now is 12:35 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
