12-28-2011, 08:27 PM   #1
Flash Compensation on K5
Hi, just a quickie - is Flash Compensation on K5 body able to adjust an external flash when mounted or is for build-in only? I'm aware of external flash unit has its own adjustment function. I use a AF-360FGZ. Thank you.
12-28-2011, 08:43 PM   #2
gedasst's Avatar
Mounted or wired with Hot Shoe
12-29-2011, 04:13 AM   #3
Anvh's Avatar
QuoteOriginally posted by gedasst Quote
Wireless P-TTL also.
12-29-2011, 04:26 AM   #4
Ash
Community Manager
Ash's Avatar
Yes you can alter flash compensation on the body AS WELL AS on the flash body. It is additive.
12-29-2011, 09:20 AM   #5
Season's Greetings!
I use a new Metz 50 AF-1 with my K-5. I can set it to Mode "P-TTL", but don't see that the K-5 Flash setting (+ or - any value) has any effect on the flash. If I need to update the flash's firmware, where/how to do this? Thank you!
Steve@totalqualityphoto.com
12-29-2011, 01:16 PM   #6
I meant mounted on the body not wired or wireless.
Thank you all!
camera, compensation, dslr, flash, flash compensation, k-5, k-5 ii, k-5 iis, k5, pentax k-5
Camera exposure compensation vs flash compensation raider Photographic Technique 4 09-29-2011 05:02 PM
Flash compensation issue on K200D Snakey Pentax DSLR Discussion 3 01-21-2011 12:09 PM
P-TTL overexposure, no more negative flash compensation Eruditass Flashes, Lighting, and Studio 11 10-09-2010 05:35 PM
difference between flash compentsation and regular EV compensation? tram57 Pentax DSLR Discussion 8 03-05-2010 08:26 PM
Flash Compensation on *ist D trd300gt Pentax DSLR Discussion 3 02-23-2009 08:54 AM
All times are GMT -7. The time now is 11:42 PM. | See also: NikonForums.com, part of our network of photo forums!
