01-01-2012, 02:10 PM   #1
Looking for a tripod for my K-5!
Hi everyone,
Just recently bought my first d-slr and i'm very amazed and impressed with the quality of the K-5 and the images it can produce. All i need now is a good sturdy tripod to make my shots even better. I've been looking online but there are way too many choices out there. I was hoping you guys could help me decide..
I have a budget of around 300$ (possibly more) for the whole set up. I think i'm leaning towards a ballhead mount also. I will mainly be using it for Macro and landscape photography, and i would love to find one that is compact and can get my camera as close to the ground as possible.
What do you think i should go with? Thanks!
01-01-2012, 02:27 PM   #2
jolepp's Avatar
Manfrotto 055XPROB + 498RC2 should be decent (currently $266.44 from Amazon). [edit: The head has a separate pan control which might be useful for landscapes. The 496RC2 would be a basic ballhead.]
01-01-2012, 02:43 PM   #3
psychdoc's Avatar
QuoteOriginally posted by jolepp Quote
That Manfrotto is a really nice tripod. I use it a lot.
However there are different kinds of heads that you can use with tripods and you might like the Manfrotto 327RC2 better. It is a joystick head. I find these type of heads much easier to use.
Amazon.com: Manfrotto 327RC2 Joystick Head with Quick Release (Black): Camera & Photo
01-01-2012, 02:49 PM   #4
Sending you a PM
01-01-2012, 02:52 PM   #5
Also Benro C-358EX is excellent for about $268 (Amazon while it lasted) and takes about double load (of Manfrotto 055XPROB), if needed. It's carbon and handles smc 1000mm f8 (11 lb lens) on Manfrotto 393 (U head) just fine. Sweet deal, if you can find one for that price. It's been "upgraded" with one for double that price. Legs have stable quick lock as Manfrotto, no slow screw-locks.
01-01-2012, 03:06 PM   #6
The 055XPROB is a versatile tripod. Any stable tripod should suffice for landscape. For macro, though, you might want to put your camera at odd angles near the ground. The 055CXPROB lets you switch the the main column horizontally and has adjustable leg angles to get lower to the ground.
Also consider the 190XPROB. It's essentially the same tripod, weighs a little less, folds more compactly, but doesn't extend as tall and has a slightly lower max capacity. I have the similar 190CXPRO3 (more expensive due to carbon fiber).
01-01-2012, 03:43 PM   #7
Thanks for all of the suggestions! I tried manfrotto at the store and i'm not sure if i like them... Can anyone tell me about davis and sandford tripods? I found a cheaper one (Davis & Sanford Voyager Lite with BHQ8 Ball Head) that can do everything i need. Or should i steer clear of that brand?
I mostly just want to make an investment, so i don't have to buy another one down the road....
01-01-2012, 04:11 PM   #8
I'm looking at "3 legged thing" tripods now. Anyone have experience with them?
01-01-2012, 04:22 PM   #9
GDRoth's Avatar
I have the Manfrotto mentioned by Jolepp and the Manfrotto pistol grip head......very happy.......
01-01-2012, 04:52 PM   #10
I think i may be going with this... Check it out
3LT X1.1 Brian - 2nd Generation
01-01-2012, 04:52 PM   #11
panoguy's Avatar
QuoteOriginally posted by RagingWinds Quote
No experience with them, but they seem awfully pricey (unless the Pound Sterling has dropped a lot recently). Oh, and I think any one of the "3-legged things" would blow your $300 limit.
Do you expect to hike a lot with your camera, and then maybe need a tripod? The reason I ask is because a tripod (like a camera) is only good if you have it with you. Many better-quality tripods that are within your price range weigh a lot (compared to your camera and a few lenses), and many lighter tripods either cost a bit more or are too unstable to really do the job of a tripod at all.
Personally, I recommend Feisol tripods and good ball head. Spend the money now and it will be years, not months, before you need something better/lighter/sturdier. Manfrotto makes nice tripods but subpar ball-heads (but nice geared and fluid heads, though... no idea why).
01-01-2012, 05:04 PM   #12
Yea i really do like feisol, but i'm not sure i can afford one plus a ballhead. Maybe you could point me in the direction of a set up that's within my price range? I would definitely like something i could hike/travel with. The ballhead on the 3LT seems really nice and built very well . I also like that they come with a five year warranty. I found the 3LT brian (carbon fiber) for $399, and i wouldn't mind spending the extra 100$ for something that would last
01-01-2012, 05:11 PM   #13
demp10's Avatar
I have the Manfrotto 055XPROB with the 804RC2 Pan Tilt head and could not be happier. B&H sell them as a kit and there is a rebate. After the rebate the kit is $198.48.
01-01-2012, 06:40 PM   #14
I am in the process of checking out tripods as well. I am looking at the some of the models by Vanguard, since they have some interesting features, including some models were the centre post can swing 180 degrees down from the horizontal position for shooting macro. There is a thread about these tripods on the forum, plus one review:
https://www.pentaxforums.com/forums/pentax-camera-field-accessories/136106-va...4-tripods.html
Vanguard Alta Pro 264AT reviews - Pentax Camera Accessories: Database and Reviews
On another thread, I was inquiring about quick release plates and someone kindly directed me towards this tripod as being a very reasonably priced beginners' model:
Dolica Proline (Aluminum) reviews - Pentax Camera Accessories: Database and Reviews
You can check out other reviews on the site here:
Tripods - Pentax Camera Accessories: Database and Reviews
01-01-2012, 07:23 PM   #15
vievetrick's Avatar
QuoteOriginally posted by demp10 Quote
I bought this same setup and while it is a little heavy (not much) I am really liking it.
camera, dslr, k-5, k-5 ii, k-5 iis, k5, pentax k-5, tripod
My new tripod KxBlaze Pentax Camera and Field Accessories 29 05-05-2010 05:19 PM
Tripod robma47 Troubleshooting and Beginner Help 7 01-09-2010 12:36 AM
For Sale - Sold: Slik 813 CF II carbon fiber tripod + tripod head (Australia) Edvinas Sold Items 5 08-02-2009 04:56 PM
what's the difference between a cam tripod and umbrella/flash tripod? vagrant10 Flashes, Lighting, and Studio 11 06-23-2009 06:56 PM
Tripod head stuck on my tripod... Buddha Jones Pentax Camera and Field Accessories 11 06-04-2008 07:34 PM
All times are GMT -7. The time now is 06:46 PM. | See also: NikonForums.com, part of our network of photo forums!
