Originally posted by rjpinaz Mike,
I had the same exact thing happen with my K-5 a month after I purchased it. I was using it all day and had taken at least 150 shots. Near the end of the day I turned it on and had the same problem you described in the original post. Turning off the camera had no effect! I removed the battery and let it sit for about 1 minute. I then put the same battery back in, and it powered up normally and conituned to work fine after that.
Fortunately, this is the only issue I have had so far with the K-5. At the time I was using firmware v1.03 and it had a shutter count of 1050.
Good Luck.
Ray
edit: I should mention that I was NOT using Live View at the time of the lockup or at any time that day.
Hi,
Interesting, word for word this is exactly what happened to my K-5 in Jan. this year. I turned the cam off and put it on the desk and promptly forgot about it. After about six or seven hours I came back to it and the first thing I noticed, the camera was quite hot. Took out the batteries (am using Pentax Grip), let the cam cool down and put fresh batteries in. Everything works properly since. Took the camera to C R Kennedy but after some 2 weeks they could not find anything wrong. Camera works faultlessly ever since. I am buggered if I know what was the matter with it.
Greetings
