01-06-2012, 01:01 PM   #1
Continuous shooting with the remote
I came across something today that I hadn't noticed before - I had my K-5 set in continuous mode (shooting birds at a feeder) and was using the Pentax remote control. The shutter fired at the "Hi" rate, even though I had set it on "Lo". Both rates work as expected if I just use the shutter button, but if I use the remote it'll only fire at the "Hi" rate. The user's manual doesn't mention this one way or the other. Not sure it makes that much difference to me, but if this isn't normal I'd like to get it looked at while the camera's still under warranty. Anybody else seen this?
01-06-2012, 01:41 PM   #2
I believe you are misunderstanding continuous mode. In continuous mode, the mirror is locked up and the shutter will fire "continuously", i.e., it will fire one frame after the other with as short a delay between frames as possible. The only control you have is how long of an exposure you want for each frame. When I do astrophotographic timelapse sequences, I set it up in continuous mode with 8 second exposures. After an 8 second frame, it is only a fraction of second before the next one starts. There is no control of the interval between frames in continuous mode.
Jack
01-06-2012, 02:19 PM   #3
RonHendriks1966's Avatar
QuoteOriginally posted by dshombert Quote
Well there is only one setting for continuous shooting with the remote control. You can set the function of the remote different in the menu. For wich you can read the manual.
I don't understand why anyone would even think about bringing in a camera about a function he is not even using in real life.
01-06-2012, 08:44 PM   #4
Well, actually, I was using it in real life. Just because it's the first time I noticed this doesn't mean I'm never going to want to use it again. And I'm pretty sure that most people, if they knew their camera was malfunctioning in some way, would want to get it fixed under warranty.
Jack - I guess you're right, I misunderstood the continuous mode that one gets via the remote. I had assumed that it was the same as the "continuous shooting" mode that one selects via the four-way controller, as described on p. 151 of the user's manual. Partly, that confusion arose from the fact that, on p. 152, in the grey-box "memo" section, it states that one "can also use the remote control for continuous shooting". That made me think that I'd be using the remote control to operate whichever continuous shooting mode I'd selected with the controller. But your explanation makes sense, thanks for a helpful response.
Dave
01-07-2012, 08:10 AM   #5
Ex Finn.'s Avatar
Not when using a wired remote, both Hi and Lo rates are functional in that mode. If you set up the camera for wireless continuous shooting then it seems to only do Hi. ( this is with Sony wireless remote so the operation is little wonky sometimes).
Cheers.
01-07-2012, 08:40 AM   #6
crewl1's Avatar
I use the mode myself quite a bit in real life for taking some of my hummingbird shots.
camera, dslr, k-5, k-5 ii, k-5 iis, k5, pentax k-5, rate, shutter
Burst/continuous shooting with remote? Tom Woj Pentax K-r 5 01-03-2012 12:42 PM
K20d remote continuous shooting problem Subi Pentax DSLR Discussion 1 10-25-2011 05:55 PM
Can IR Remote be used for continuous shooting? mojoe_24 Pentax DSLR Discussion 11 07-13-2011 12:40 PM
Which mode are you? Single shooting or continuous shooting? RonakG Photographic Technique 39 03-06-2011 02:08 PM
K-7 Continuous Shooting brosen Pentax DSLR Discussion 17 08-29-2010 06:24 PM
All times are GMT -7. The time now is 10:50 AM. | See also: NikonForums.com, part of our network of photo forums!
