01-07-2012, 12:59 PM   #1
telly0050's Avatar
Battery Grip, how does power calculate?
I have a cheap $50 "professional" battery grip on my K5.
The shutter button, green & AF, wheel all works well, except I have a little question about the battery.
I put in 6 fully charged AA battery, and the top panel screen of the camera shows that I have 1/3 battery left.
I already went to the "select battery" option and chose "grip first".
Also in that option panel shows my camera has 1/3 battery, but grip has no battery.
What is the problem here?
Is the battery slot broken?
01-07-2012, 01:41 PM   #2
manacho2005's Avatar
More than likely it's the aftermarket grip. I had the same problem with a chinese grip for my k10. I could shoot all day with a "dead battery". I lucked out and found a cheap Pentax grip on Ebay, and never had any inaccuracy since.
Matt
Pentexan
01-07-2012, 01:48 PM   #3
telly0050's Avatar
so i guess it is basically a "you pay for what you get" issue.
just took out the original battery in the camera and use only the AA in the grip.
somehow it does power up, but won't last more than 2 minutes before battery alert pops up and shut off :/
01-07-2012, 03:54 PM   #4
The battery meter on the top shows the power available in the active battery- you need to open up the menu if you want to see both batteries.
If the battery in my grip is almost flat, the top lcd will display 1/3 even if the internal batt is fully charged. Then, once there's absolutely no juice left in the grip, it should switch over to the main battery.
01-07-2012, 08:09 PM   #5
QuoteOriginally posted by telly0050 Quote
You may actually have a different issue than I did, bc my camera wouldn't shut off; it would just display a "depleted battery" while I kept on shooting. Seems like your camera may not like the grip or the grip itself is draining the battery
01-08-2012, 12:18 AM   #6
mikeSF's Avatar
thanks for this info Adam...this had confused me when i first got the grip.
01-14-2012, 10:47 AM   #7
telly0050's Avatar
problem defined.
when i use the battery tray instead of AA tray on the grip, the battery display full on the camera even the camera itself doesn't has battery.
so looks like my AA tray is broken or something :/
01-14-2012, 01:32 PM   #8
Docrwm's Avatar
problem defined.
Sorry to hear about your troubles. Have you made certain that each AA battery is both completely seated and inserted in the correct direction?
01-14-2012, 03:00 PM   #9
telly0050's Avatar
QuoteOriginally posted by Docrwm Quote
yes i did, i even try different sets of AA, still no help :/
im gonna get a cheap set of battery from ebay and juz stuck it in the grip
01-14-2012, 04:54 PM   #10
Docrwm's Avatar
One last thought - have you cleaned the contacts both those to the batteries themselves and those from the tray to the grip?
01-14-2012, 05:28 PM   #11
telly0050's Avatar
didn't try it.
but the AA power actually goes through the camera, it just shows battery dying..
01-18-2012, 03:03 AM   #12
I assume that your grip will also accept the standard Pentax battery - what does the grip show when inserting this battery in the grip. Full charge? or 1/3 charge. First case: trouble is cause by AA batteries in the grip (could be caused by grip or batteries). Second case: it all about the grip.
01-18-2012, 03:17 AM   #13
cbope's Avatar
I believe the moral of the story is.... you get what you pay for.
I refuse to buy cheap Chinese knock-offs, regardless of the product. You will get no support from the "company" that made them and they are very likely not performing anywhere close to "the real thing".
Save your money and buy the real Pentax grip if that is what you want/need, and stay away from cheap Chinese crap. Note, I am not insinuating that everything made in China is crap, far from it. Legitimate, quality manufacturing can be done there. But knock-offs are NOT manufactured by quality-minded companies. It is mass produced junk.
01-18-2012, 08:32 AM   #14
telly0050's Avatar
actually the grip works perfectly fine except the AA problem.
standard battery works on the grip, i have the standard battery on the grip (camera battery slot is empty).
i guess buying a cheap standard battery will fit my need.
battery, camera, dslr, grip, k-5, k-5 ii, k-5 iis, k5, option, panel, pentax k-5
For Sale - Sold: K20d with Battery Grip and extra battery + Vivitar 383 Flash mrdfred Sold Items 5 11-05-2011 09:33 PM
For Sale - Sold: Camera, cable release, battery grip, flash, battery pack, 3 lenses and radio t WMBP Sold Items 20 07-15-2011 09:12 AM
For Sale - Sold: K-5, K-7 Battery Grip (Phottix) incl. 2nd Battery (Hähnel) (Worldwide) pentmax Sold Items 5 03-21-2011 03:10 AM
For Sale - Sold: Pentax D-BG2 Battery Grip in Like New condition + Generic Battery jjdgti Sold Items 2 07-15-2010 06:06 PM
For Sale - Sold: Pentax 10-17mm Fisheye, AF 360 Flash, D-BG2 Battery Grip, D-L150 Battery, Remo dazman Sold Items 19 03-31-2010 03:48 AM
All times are GMT -7. The time now is 12:11 AM. | See also: NikonForums.com, part of our network of photo forums!
