Originally posted by Purusam I want to buy a teleconverter for my k-5
is there still companys producing teleconverters like Kenko 1.5X Pz-AF Teleplus SHQ Teleconverter ?
i want it on my sigma 150-500 mm so the sigma teleconverter i cant use.
if your sigma is a screw drive AF lens, and not an HSM lens then the sigma TC should work. To check is easy, just ,make sure the lens has a 35mm diameter opening at the rear element, and 12mm recessed (minimum) rear element, If the lens meets these two conditions, and the lens is screw dreive the sigma TC should work
Note however, that due to the maximum aperture of F6.3 at 500mm, NO TC will permit the AF to function correctly as this really needs to have a total maximum aperture in the range of 6.7-7 for AF to work reliably.
As a result, you will be relegated to MF.
