01-16-2012, 04:23 PM   #31
falconeye's Avatar
QuoteOriginally posted by EugenePanich Quote
Re sharpening - theoretically, any image processing (including sharpening) applied before super resolution leads to poorer resolution increase. So it's better to apply sharpening after super resolution. But in practice that can be wrong in some cases, of course .
I do agree. But then you need to know the correct point spread function, i.e., the one used for your lens and the raw conversion. PhotoAcute knows this and this is why they generate PSFs from controlled test shots done by their users.
However, such test shots normally suffer from non-optimum focus and other sources of blur. Moreover, most camera/lens combinations are simply unsupported by PhotoAcute. This is why I am doing it the way I do.
camera, dslr, feature, k-5, k-5 ii, k-5 iis, k5, pentax k-5, sensor, shift, stars
Is Av Shift and/or Tv Shift in TAv Mode possible. robert_s Pentax K-5 & K-5 II 3 09-30-2011 09:03 AM
K200D sensor shift problem Undefined (photo) Pentax DSLR Discussion 6 03-24-2011 03:05 AM
Possible to make a tilt shift lens out of a 50mm on a crop sensor? Abstract Pentax SLR Lens Discussion 10 02-07-2011 03:47 PM
New K-7 owner: ? about sensor shift javarob75 Pentax DSLR Discussion 1 12-26-2009 09:31 AM
Sensor shift during "long" exposures eclipsed450 Pentax DSLR Discussion 11 12-18-2009 12:51 PM
All times are GMT -7. The time now is 01:41 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
