Originally posted by GDRoth
Boy, will this be a dumb question;
Why not focus using the center spot, then move camera if you wish to shift comp?
Not a dumb question, and it is a workaround. I just find that often, when working with a narrow depth of field, the simple act of recomposing after focusing can result in a misplaced plane of focus.
Originally posted by wlachan
Not surprising since the AF sensor is adjusted and held by 3 screws. AF isn't accurate because the sensor was loosely adjusted in the factory, then compensate through software. Since the optical path isn't aligned to begin with, each of the 11 points (not really points btw) will behave differently with different lenses. A QC disaster.
Interesting. Perhaps someday I'll have to send the camera out for adjustment. But I'm not desperate - I'm just curious at this point. I'm also going to try some other lenses to see if the behavior is similar.
