01-12-2012, 03:09 AM   #16
sterretje's Avatar
QuoteOriginally posted by Pa. Patriot Quote
Can you link or post something to support this claim please
https://www.pentaxforums.com/forums/pentax-k-5-forum/167780-using-m-lens-lv-k-5-a.html / post #12
01-12-2012, 03:12 AM   #17
dosdan's Avatar
I was suffering from that bug (https://www.pentaxforums.com/forums/pentax-k-5-forum/167780-using-m-lens-lv-k-5-a.html) and yes, F/W v1.12 has fixed it on my K-5.
Dan
01-12-2012, 05:05 AM   #18
JohnBee's Avatar
SEE: https://www.pentaxforums.com/forums/pentax-k-5-forum/165486-need-your-help-is...g-problem.html
I updated FW when it was slipstream(fr. 1.11.23.15 to v1.11.23.19)and confirmed the problem has been fixed
01-12-2012, 05:23 AM - 1 Like   #19
QuoteOriginally posted by TOUGEFC Quote
Just updated mine, and it does look like the flash over-exposure problem is now fixed.
Yes! My prayers have been answered. Will update tonight. Still on 1.03.
Regards,
--Anders.
01-12-2012, 05:28 AM   #20
JohnBee's Avatar
QuoteOriginally posted by asp1880 Quote
Regards,
--Anders.
So that's makes two silent issues addressed in the FW.
Perhaps someone should make a list?
01-12-2012, 05:56 AM   #21
Freezing when push "green" button in LV mode happens also with M42 lens (with adapter M42->K). I discovered this long time ago.
After some test's, some thinking and calculation, I ended with following conclusion:
- This happens, when you tried to metering situation, below low limit of metering system in K-5 (which is -2 EV, i believe).
So, you try to meter scene with pushing "green" button, and K-5 try to meter and obtaining some adequate speed value.
But, because metering system is not able to catch the enough light, K-5 metering is cycling, trying and trying and trying again... and so on to infinity. and K-5 is freeze.
When some light fell in metering sensor (above -2 EV), the metering system finally do it's job correctly, and k-5 unfreeze.
I suggested, this is normal behavior of metering system, so I stop worried about, and when this is happen accidentally, I put some light in front of lens (with lighter for instance) and K-5 unfreeze complete.
Anyway, I'm glad that this is fixed now. So, I may (uuummmm, or may be not ) upgrade from my currently 1.03 to 1.12
(I hate that "new" behavior of K-5, in comparison with K10 before, that's no way to downgrade firmware to the previous versions)
01-12-2012, 06:00 AM   #22
JohnBee's Avatar
QuoteOriginally posted by jorro_z Quote
I actually encountered this issue fairly often in low light scenes with manual lenses(none contact). And since it never happened on any other body(K200/20D), I contacted Pentax to open an official bug report with them.
And I'm really glad they fixed it too. Now the K-5 I can meter all the way to 20s without as much as a hiccup.
01-12-2012, 06:01 AM   #23
JayBee's Avatar
QuoteOriginally posted by Gimbal Quote
Has anyone seen the main problem "a band of light green noise" this firmware is fixing?
I have - on just a few random astro shots. Usually with the DA* 50-135, but that could be unrelated. I hadn't seen any reports of the problem anywhere, so am surprised to see it addressed in a firmware update.
(had to edit this - once I dug up the photos, I see they were with the Sigma 100-300mm lens)
01-12-2012, 07:07 AM   #24
bobmaxja's Avatar
Just updated. I agree seem flash have been rebalance. Exposure seem better
01-12-2012, 08:13 AM   #25
QuoteOriginally posted by dosdan Quote
Dan
QuoteOriginally posted by JohnBee Quote
Awesome, good news, thanks.
01-12-2012, 08:16 AM   #26
fccwpe's Avatar
Update is now on Pentax USA site.
01-12-2012, 08:19 AM   #27
LaurenOE's Avatar
Sounds like the "Aurora Borealis" fix to me!
01-12-2012, 08:31 AM   #28
ogl
ogl's Avatar
Flash work is fixed.
01-12-2012, 08:33 AM   #29
Manual Flash Yn-560 problem Fix . Now it does not freeze the flash anymore
01-12-2012, 10:56 AM - 1 Like   #30
Tom S.'s Avatar
I up dated. So far, it's kept my lens release button from falling off and my mirror from flopping.
camera, dslr, firmware, k-5, k-5 ii, k-5 iis, k5, pentax k-5
New K-x firmware? shoebox Pentax DSLR Discussion 12 04-12-2010 08:45 PM
Firmware Pentastic Pentax DSLR Discussion 8 03-17-2010 07:49 PM
KX Firmware HELP! kparkypark Pentax DSLR Discussion 6 02-27-2010 01:37 PM
Firmware 1.03 K7er Pentax DSLR Discussion 44 02-25-2010 04:07 PM
K-7 firmware 1.03 Jadran Pentax DSLR Discussion 3 02-17-2010 10:19 AM
All times are GMT -7. The time now is 08:47 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
