01-14-2012, 01:14 PM   #1
houstonmacgregor's Avatar
K7 to K5
Have K 20 and K7 and was thinking of selling and getting the K5. Is the K-5 that much of a upgrade/improvement vs the K7. Don't do a lot of high ISO photography
Thanks
01-14-2012, 02:41 PM   #2
axl
K-5 has much better sensor, delivering much less noise in shadows even at lower ISOs and much more dynamic range, so I was told. Apart from that it's main improvement over older bodies seems to be AF.
01-14-2012, 05:23 PM   #3
QuoteOriginally posted by axl Quote
K-7 image quality is very good but the K-5 definitely has a better dynamic range. Not sure about the actual performance of the AF being better, my K-5 seems to hunt quite a bit, sometimes even refusing to take the snap - but perhaps that has more to do with my DA* 16-50?
01-14-2012, 05:35 PM   #4
LaurenOE's Avatar
I had a K7 and did what you are doing, that is, is it better?
YES!
I never regretted the change-over.
I got a good price for my K7, but these days I doubt you will get as much as I did when I sold mine.
At around $400-600, as the going rate for a used K7, I would recommend keeping the K7 as a back up if you go the K5 route.
If you can get more? Great!
01-14-2012, 05:47 PM   #5
QuoteOriginally posted by robr7 Quote
Sometimes all needed is to tune the microadjustment correctly. I found that when it is done wrong, camera my even slow down in AF or refuse to lock on target. With correctly adjusted AF there is no problem even in considerably low light.
Just do not accept poor performance. That is not OK with K-5.
01-15-2012, 06:20 AM   #6
I had the K20D and switched to the K7 and now after 1.5 years have finally bought the K5. It i a vast improvement on the K7
01-15-2012, 08:52 AM   #7
ogl
ogl's Avatar
QuoteOriginally posted by houstonmacgregor Quote
Thanks
I think that K-5 is upgrade of K-7. Much - hard to say...I don't think so...
RAW files at ISO1600 is rather noisy without NR and any PP in bad light condition.
But better structure of noise and easy to apply NR in converter...
And sometimes ISO1600 (with small amount of dark places) are outstanding with GOOD sharpness and GOOD details.
DR of K-5 is outstanding - never seen before...
As for me - exposure is very good and WB is SIMPLY OUTSTANDING.
As for AF - I see very small difference in AF speed and accuracy vs my K200D. There is. Of course.
A bit faster, a bit steady in low light...AF-C can work really.
But...The same dependence of lighting condition.
1/125 is still the same (blur sometimes).
To say honest my K200D has no need of any AF adjustment with all my FA lenses.
K-5 needs.
BUT...I like K-5 VERY MUCH. It was the love at first sight. Paradox.
01-15-2012, 12:59 PM   #8
vrrattko's Avatar
apart from Better Dynamic Range and Better AF...there's not much of an advantage over K-5....as you said you're not interested in high iso.....K-5 has some nice features, but at low iso K-7 is pretty close, unless you need extended dynamic range
camera, dslr, k-5, k-5 ii, k-5 iis, k5, k7, pentax k-5
All times are GMT -7. The time now is 09:49 PM. | See also: NikonForums.com, part of our network of photo forums!
