Yesterday morning I was out photographing the dawn on top of Mam Tor in Derbyshire, UK. Temps probably around -2 degrees C. I was out for around 3 hrs, standing around in the cold. I used various lenses, 16-45, 35mm Macro and towards the end of the session, I had the 77mm limited on - had two weird exposures. Took loads of frames that were fine, but for two exposures only, close but not sequential to each other, I think (but can't swear) that the camera display indicated 1/30 sec exposure. The shutter actually stayed open for 30 secs (so totally white frame was the result). I had ISO set to 80 throughout the session, camera in Aperture Priority, battery not full (over 300 shots taken since full charge) but not flat either. Before and since the camera has behaved perfectly.
Could be user error but no idea what I've done...anyone have any bright ideas?
Done a search but can't see any mention of similar problems.
I've kept the affected images so can query the metadata.
Cheers all
Paul
