01-17-2012, 06:23 PM   #1
K5 Underexposure problem with Aperture 3
Has anyone else experienced an underexposure problem with their K5 when uploading into Aperture 3? I never had issues with this before until recently (maybe last month). I always shoot raw. I have not downloaded the recent firmware update as I think it only involves GPS. I also use LR as well and when importing my pics into there the exposures are fine. In Aperture 3 I have to seriously increase the exposure as well as brightness to get anything out of them. In camera on the LCD they look fine. I think I narrowed it down to Aperture 3 and not the camera. Anyone having similar experiences? Thanks.
Jason
01-17-2012, 07:37 PM   #2
bobmaxja's Avatar
I believe this is more appropriate in the Digital Processing, Software, and Printing section as for sure the K-5 is not at fault here.
See you need to change your setting in Aperture
01-18-2012, 12:38 AM   #3
hcarvalhoalves's Avatar
QuoteOriginally posted by Bigkidneys Quote
Jason
Probably the latest Apple Camera RAW updates messed up the settings for K-5 RAWs. I'm still stuck on Camera RAW Update 3.0 because it's the last version that reads my K-x RAWs correctly.
Here's a list of the versions, and which cameras each version supports. You might want to downgrade to the first version to provide K-5 support, to avoid later-introduced bugs:
Mac OS X v10.5: Supported digital camera RAW formats
You don't see this issue in LR because it uses it's own RAW converter. Apple RAW support is lacuster for other brands besides Nikon and Canon, apparently.
01-18-2012, 04:53 AM   #4
Thanks for that. I have been running lion for months now and this just recently popped up. How exactly would I downgrade?
01-18-2012, 03:06 PM   #5
jackassp's Avatar
Jason
Aperture 3 working fine here with my K-5.
You probably should try re-installing it.
Cheers, Jack
01-18-2012, 03:29 PM   #6
boriscleto's Avatar
QuoteOriginally posted by jackassp Quote
Cheers, Jack
Are you using PEF or DNG? And does it affect both?
Try trashing the prefs first.
Hard Drive/Users/(Your user)/Library/Preferences/com.apple.aperture.plist
You could also try deleting the cache files.
Delete all the files in the following folders
Hard Drive/Library/Caches
Hard Drive/System/Library/Caches
Hard Drive/Users/(Your user)/Library/Caches
Then restart your Mac.
In 10.7 the User/Library folder is hidden so you will have to use Go to Folder... in the Go menu or use the terminal.
01-19-2012, 03:02 AM   #7
Another happy Aperture 3 user, but was having issues when I first updated to Lion it was so slow!
All good now though.
01-19-2012, 06:34 AM   #8
Turn off highlight correction under d-range settings on your cam.
01-22-2012, 07:35 PM   #9
Simico, you rock! That was exactly it. Thanks everyone for helping out on this.
aperture, camera, dslr, fine, k-5, k-5 ii, k-5 iis, k5, k5 underexposure, pentax k-5, underexposure
Does Tamron 17-50 underexposure problem still exist? jake123 Pentax SLR Lens Discussion 10 02-15-2012 05:33 PM
New Pentax KX, problem with double shutter movement leading to underexposure Tricerator Pentax DSLR Discussion 21 10-30-2011 09:01 PM
50mm Underexposure Problem Halco Troubleshooting and Beginner Help 4 09-15-2009 06:32 PM
Weird K10D underexposure problem Kirivon Pentax DSLR Discussion 9 12-19-2008 04:54 AM
problem with underexposure joaosoares5 Pentax DSLR Discussion 7 03-23-2008 08:50 AM
All times are GMT -7. The time now is 07:42 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
