Originally posted by Andrew Crouch I have only had a K5 for a few weeks, but I have noticed a tendency to a significantly blue cast to most photos (not just the sky - all colours) when using White Balance set to AWB in bright Australian sunlight. Changing White Balance to 'sunlight' fixes this, but Auto White Balance doesn't seem to be able to cope with it. Is this to be expected with the K5? I should add that I have only had older manual SMC prime lenses to work with so far.
Try to set A2 or A3 correction to the AWB for a warmer color cast.
To set AWB correction press WB button on the pad, then right to enter AWB correction menu. Then press right 2 or 3 times to set A2 or A3 correction. Terminate with OK 2 times.
With A3 AWB correction, colors are the same as with sunlight WB.
