01-24-2012, 05:33 PM   #1
billylh's Avatar
K5's Shake Reduction
What are your thoughts/experience with SR and how effective it is on the K5?
My issue is that it doesnt seem very effective as taking hand shots(keeping it as steady as possible) will still produce a ghost. This is really noticeable for me when I tried taking pictures of some text on paper.
I have an Olympus E-420 with no iamge stabilization and it seems to be able to take much clearer and sharper pictures. I know this isnt supposed to be the case but it is.
I also suspect a back focusing issue but the above problem isnt a blur, its a second image offset.
01-24-2012, 05:36 PM   #2
JinDesu's Avatar
The question comes down to, are the settings the same? Lenses? What lens are you using?
01-24-2012, 05:37 PM   #3
Anvh's Avatar
A picture is worth a thousand words, and even more if you leave the EXIF in it.
Beside that was it handheld?
01-24-2012, 05:37 PM   #4
It won't help with front-back issues -- like macros where a millimeter of difference will unfocus the image, so if you're talking about text where you are jamming the lens right up to the target a tripod (or more light and faster shutter) will serve you better. And of course it does have limits (gives you a couple of extra stops at best off of focal length/shutter speed rule).
I was wondering if it had improved since the K-7 -- someone did a study showing that around 1/100 sec, the SR wasn't effective. Anybody know about that?
01-24-2012, 05:57 PM - 1 Like   #5
jatrax's Avatar
Shake reduction works well on the k-5 within it's limits. It will give 1 or 2 stops advantage sometimes a bit more. But it is not a replacement for good technique nor does it work miracles. It is not going to magically make 1/2 second shots look good. What settings are you using? Aperture, speed, lens and ISO.
Also keep in mind that Pentax SR takes a moment (well seconds anyway) to "spin up" or "lock in" or whatever. The SR is only working when the little green hand shows in the viewfinder.
01-24-2012, 06:38 PM   #6
calsan's Avatar
One possible theory is that the E420 is 'only' 10MP - therefore shots will appear sharper at 100% (pixel peeping) than shots taken with a higher resolution camera. This was something I noticed going from the K10 to K7.
If you view shots at the same actual size (ie printed) then the difference is non existent.
My K7 did seem to have the 1/100th problem mentioned by vonBaloney above, but when I consciously paid attention to the little green hand in the view finder, I realized that I was clicking the shutter before shake reduction had kicked in. I had imagined there was a problem with my K7 giving mirror slap and double images, but with more attention to my technique, the double image problem went away. Just my experience with my camera, your mileage may vary.
01-24-2012, 06:49 PM   #7
Rupert's Avatar
Seems as good as or slightly better than on my K20D...which I found to be very useful and mostly excellent...within reason. It won't cure all that can give a shot the jitters.....but it is a definite advantage over not having it.
Regards!
01-24-2012, 06:56 PM   #8
Yes, the SR is good as long as its turned on and working. I have no problem picking out my shots where I forgot to switch it back on after a BIF or tripod session and then took some 300mm hand-held shots at 1/250.
01-24-2012, 07:05 PM   #9
I'd look at the lens. Ghosting a high contrast subject could mean misalignment or haze.
I would think an SR problem would show some blurred images among sharp ones. Are you getting the same results with SR off?
I haven't used short lenses very much at all but with long ones hand held SR definitely works.
01-24-2012, 07:17 PM   #10
telly0050's Avatar
i have same problem.
when i am using a 50mm focal length, i will always have to make sure my shutter speed is over 1/50 even with SR on...
with 1/30 it sometimes produce ok picture, with 1/20 i hardly get any keeper, and with 1/15 i never make it to work. (i did try to keep my hand as sturdy as i can)
am i doing something wrong or my camera has some problem?
01-24-2012, 07:56 PM   #11
telly: what results do you get without SR?
01-24-2012, 08:02 PM   #12
telly0050's Avatar
QuoteOriginally posted by derekkite Quote
without SR, nothing works if lower than safe shutter.
that said, the SR does help, but still hardly useful...
(i still remember i have a low end nikon d60 with a kit stabilization lens, and i go 1/15 with all focal length)
01-24-2012, 08:09 PM   #13
QuoteOriginally posted by telly0050 Quote
You are doing something wrong. Or have shaky hands.
01-24-2012, 08:33 PM   #14
telly0050's Avatar
yea, that's why i am trying to find out what did i do wrong.
01-24-2012, 08:34 PM   #15
hcc
hcc's Avatar
I would not comment on the shots without SR. But with SR, you need to wait for the SR confirmation (xxxhexagonxxx shaking hand symbol in the view finder) before your shoot to get the full benefit of SR. Simply, focus, half-press the shutter button and wait (1-2 s typicaly) for the SR confirmation symbol to appear.
Hope that the info may help.
camera, dslr, issue, k-5, k-5 ii, k-5 iis, k5, pentax k-5, pictures
Shake Reduction Wolter Pentax K-5 & K-5 II 11 04-08-2011 06:50 AM
Shake Reduction on or off? GoldenRGuy Pentax DSLR Discussion 7 02-16-2011 08:37 PM
When to use Shake Reduction? Todd Adamson Troubleshooting and Beginner Help 9 11-04-2010 05:36 AM
Do you always have shake reduction ON? gawan Photographic Technique 18 08-01-2010 02:36 PM
Shake Reduction hannsg Troubleshooting and Beginner Help 5 06-11-2010 03:45 PM
All times are GMT -7. The time now is 09:12 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
