02-01-2012, 06:52 AM   #16
JimD's Avatar
QuoteOriginally posted by octavmandru Quote
Take the lens off, put on the mount cap.
Turn camera on.
The contacts don't need to be shortened. Usually the M42's don't do it, and they are as manual as can be.
Octav
I'll try that later. I don't have the cap with me at this time.
I've just emailed Pentax UK to get their response but they haven't been too quick to answer in the past.
02-01-2012, 11:17 AM   #17
lammie200's Avatar
So...?
So you have your camera off, change the lens, turn the camera on, get no prompt to input the focal length of the lens, right?
When you then go to the menu item for inputting focal length, what is it set on? Is it set to the last length you inputted, the length of the lens that you attached, or something else?
02-01-2012, 11:20 AM   #18
I have several KA lenses, plus a couple of M lenses. I always get a prompt? Let us know what you hear from Pentax.
02-01-2012, 11:32 AM   #19
JimD's Avatar
QuoteOriginally posted by lammie200 Quote
The last length I inputted
02-01-2012, 11:49 AM   #20
lammie200's Avatar
Not sure...
QuoteOriginally posted by JimD Quote
I am not sure what causes that, but I have had the same experience a handful of times. I do think that it is settings/sequencing issue because I seem to recall that I if I shut the camera off and remounted the lens I would be prompted for FL again. Let us know what you find out.
02-01-2012, 12:28 PM   #21
Den
Den's Avatar
Seems you do have a problem, as every M lens I have mounted prompts for FL when I turn the camera on.
02-01-2012, 05:15 PM   #22
The only other thing I can think of is if you are in a mode where SR is turned off automatically. Bulb mode for example.
02-01-2012, 10:53 PM   #23
JimD's Avatar
QuoteOriginally posted by derekkite Quote
Not that either
02-02-2012, 12:02 AM   #24
lammie200's Avatar
Hoa about...
Not that either
Do you have Aperture Ring Enabled?
02-02-2012, 02:10 AM   #25
JimD's Avatar
I've tried it on permitted and prohibited.
I think I've tried about every combination on the camera now.
02-02-2012, 04:26 AM   #26
octavmandru's Avatar
Did you try to do a custom function reset?
02-02-2012, 08:51 AM   #27
Does the hand icon show up in the viewfinder to indicate SR is on?
02-02-2012, 09:30 AM   #28
fs999's Avatar
Do you have a grip with a button pushed or a cable release attached and switched on ?
Something is preventing you to enter the focal length... A pushed button perhaps.
02-02-2012, 09:37 AM   #29
Jean Poitiers's Avatar
Always promtped using variety lens ...
Bonjour,
I always get the prompt immediately ... whether using my Pentax M's (75-150, 200, 50) or A50.
Same is true with my Adaptall-2's (no difference for a PKM or PKA mount), old Sigma mirror and MF Cosina's.
I never use the menu function route ... even when changing the FL for a manual zoom (like the M 75-150 or a Tamron) ... just turn off and back on and select desired FL ... sometimes shooting at the lowest FL of the zoom or switching up to the highest ... and sometimes just splitting the middle of the range and not changing at all.
Hope you find a solution. There have a lot of good suggestions ... keep us posted ... Merci.
Allez, courage - J Frog
02-02-2012, 07:13 PM   #30
No. Doesn't happen.
I never change the lens with the camera switched on.
At the moment the F.L. is set to 200mm. Focus mode to manual and mode dial to M. I just tried my 20mm, 28mm, 50mm and 100mm. No prompt when I switched back on.
I set the dial to TAV and focus to AFS and nothing and then I tried all manual settings again. Still no prompt.
I don't have a K-5 yet. Does this problem have something to do with TAV? Does the camera prompt for a focal length when in manual mode?
camera, dslr, input, k-5, k-5 ii, k-5 iis, k5, menu, pentax k-5
Manual Focal Length Input WhichWayIsUp? Troubleshooting and Beginner Help 11 12-15-2016 05:32 AM
Sears Manual Lenses - Input? mishmatta Pentax SLR Lens Discussion 7 10-01-2010 03:47 PM
f stop input for manual lenses? axl Digital Processing, Software, and Printing 6 06-30-2010 05:09 AM
What do I input when using old manual focus lens? lurchlarson Pentax SLR Lens Discussion 10 02-23-2009 02:57 PM
Input focal length for a manual lens jpzk Photographic Technique 11 01-14-2009 08:50 PM
All times are GMT -7. The time now is 12:33 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
