02-07-2012, 09:47 AM   #1
Pentax k5 with 50mm 1:1.7 and shutter speed
I'm sure this is a dumb question and has been asked several times but here it goes. I have a Pentax K5 and an Asahi SMC Pentax-M 1:1.7 50mm lens. I know how to set the aperture but I can't seem to set the shutter speed. The only time it changes is when I push the green button. Is there a way to change it manually? Thanks for your help.
02-07-2012, 10:08 AM   #2
jase036's Avatar
Make sure you have the mode dial set to M, then use the front e-dial to select your shutter speed, aperture is set via the aperture ring on the lens in any lens that doesn't have the A setting (such as the M series).
02-07-2012, 12:40 PM   #3
Thanks. I feel like such an idiot. I had it in M but I forgot about the front dial. I just recently switched to the K5 from the K100D. A big jump and I'm still getting used to all the extra buttons and features. Thanks for being kind to an idiot.
02-07-2012, 12:47 PM   #4
Here's the full guide to shooting manual lenses
https://www.pentaxforums.com/forums/pentax-lens-articles/110657-how-use-manua...7-k-x-etc.html
02-07-2012, 02:44 PM   #5
jase036's Avatar
QuoteOriginally posted by smack1019 Quote
Don't beat yourself up about it, I shot with a K110D and a K200D before steeping up to the K5 and it took me a while to start using the front dial without having to think about it consciously. No one on Pentax forums would think you're an idiot for asking an honest question. We're all here to learn and we're all here to help.
02-07-2012, 03:06 PM   #6
Pontax's Avatar
I have made a user setting for MF, I have moved shutter speed to the back e-dial so I can meter with DOF preview mode (index finger) and change shutter speed (thumb).
And you are not an idiot. You have a Pentax.
02-08-2012, 07:18 AM   #7
Jean Poitiers's Avatar
QuoteOriginally posted by Pontax Quote
Bonjour,
Ditto ... I have done the same for the rear e-dial (+ aperture for the front) ... and you customize the same for the other settings, Tv, Tav, etc., as well.
And agreed ... definitely no idiocy here ... it's a Pentax!
Allez et salut - J Frog
02-08-2012, 10:12 AM   #8
Captn Ahab's Avatar
There's a saying that when you assume something, you make an "ass" of "u" and "me". Well, I assumed that I could set shutter speed manually with the e-dial with my SMC Pentax-M 1:1.7 50mm lens. Then I read this thread only to find out that I assumed wrong. Put camera in manual, set aperture with the ring, press green button, and bingo. I learn something new about my K-5 every day. Still wish it had tethering option.
03-04-2012, 11:56 AM   #9
Have spent the weekend trying to bond with my new baby, named K-5. I have a couple M-lenses from my old MX (along with a new DA 55-300). I flipped the front & rear dial to adjust shutter as you said, and it is more convenient. What is the advantage of creating a user mode for this? Are there other settings you saved in your "MF" user mode?
03-04-2012, 03:33 PM   #10
Pontax's Avatar
QuoteOriginally posted by ElKay23 Quote
Well not really, I like to keep shutter speed on the front dial in M mode when I use a AF lens, to keep a constancy through the modes and because shutter speed is on the top of the display.
There could be some settings that would be convenient when shooting with a MF lens. I have made some custom ISO NR, that's all.
03-04-2012, 03:52 PM   #11
jeztastic's Avatar
I use my middle finger on the front e-dial, and index finger to hold down DOF preview. That's on the K10D, I don't think it will let me change e-dial in User mode.
50mm, camera, dslr, k-5, k-5 ii, k-5 iis, k5, pentax, pentax k-5, pentax k5, shutter, speed
How I set up shutter speed on my PENTAX spotmatic to sync w svn.ictus Pentax Film SLR Discussion 6 09-09-2011 07:51 AM
Aperture/shutter speed problem with 50mm f/2 vcw79 Pentax SLR Lens Discussion 5 03-25-2011 07:02 AM
Pentax KX Shutter starting to stuck at slow shutter speed. Spirit722 Pentax Film SLR Discussion 7 03-03-2011 09:49 PM
Shutter speed on K-x CrabShadow Troubleshooting and Beginner Help 7 08-14-2010 06:46 AM
Pentax K-x Shutter Speed, ISO, Low Light.. jbarcus81 Pentax DSLR Discussion 4 02-14-2010 07:26 AM
All times are GMT -7. The time now is 04:34 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
