02-10-2012, 09:31 AM   #1
K5 front wheel "sticking" at low temps
I bought one of the first K5s, Dec 2010, and later had it swapped for a new one because it had the infamous "string of pearls" sensor contamination.
The original also had sticky wheels - both front and back ones. As one adjusted e.g. the shutter speed it would skip some values and sometimes go up and then down even though the wheel was turned in the same direction.
I have just taken my K5 out, in temps of about 0C, and the front wheel was barely working. As it warmed up, it was OK.
The camera is now out of warranty...
With this issue on 2 out of 2 cameras, it probably isn't exactly rare.
Is there a fix for it which actually works, and does anyone know roughly how much Pentax would charge for it?
Otherwise, it is a great camera I had the K200D and the IST-DL before that. The K5 improves on the K200D usefully, with its higher usable ISO settings which make the TAV mode useful for most shooting.
02-10-2012, 09:52 AM   #2
PFH
PFH's Avatar
Last week end I was out with my K-5 in -17C, no problems.
I never had any problems with my K-7 either.
02-10-2012, 10:22 AM   #3
Mike.P's Avatar
QuoteOriginally posted by peterh337 Quote
Where did you buy it from?
2 year warranty in the UK if bought from a Pentax pro dealer.
02-10-2012, 11:44 AM   #4
Park Cameras, Burgess Hill, UK.
Unfortunately there is no way to replicate this issue in the shop
02-10-2012, 03:14 PM   #5
Ex Finn.'s Avatar
You could put the camera in a zip-lock bag, place it in a cooler with ice and take it to the shop nice and chilled.
camera, dslr, front, k-5, k-5 ii, k-5 iis, k200d, k5, pentax k-5, wheel
Post your "Park Bench" "or "Picnic Table" images tessfully Mini-Challenges, Games, and Photo Stories 1347 1 Day Ago 12:52 PM
Do custom "artistic" or even "funny" lens caps evenexist? lovemehate Pentax SLR Lens Discussion 35 02-10-2016 09:10 AM
Don't say Pentax "Q" in French ... "Q" = "cul" = "A--" Jean Poitiers Pentax Q 52 11-10-2013 06:25 AM
K-x "aperture priority" records as "automatic" in meta data charlestm Pentax DSLR Discussion 3 12-05-2011 12:12 PM
Problem with E-dial (or "Jog wheel") on DS: Solved! Syb Pentax DSLR Discussion 10 04-06-2010 07:07 AM
All times are GMT -7. The time now is 01:46 PM. | See also: NikonForums.com, part of our network of photo forums!
