02-10-2012, 10:53 AM   #1
TheM0nkeyM4n's Avatar
Architectural lens / Perspective control lens
Greetings Pentaxians,
Im in need of a Architectural lens / Perspective control (Tilt and shift) lens for my trusty K5... Does any one have any ideas..?
02-10-2012, 12:04 PM   #2
RioRico's Avatar
See https://www.pentaxforums.com/forums/lens-clubs/91033-tilt-shift-lens-club.html
Otherwise: The cheap'n'dirty solution is a Lens-in-a-Cap PC 35/11 but it doesn't tilt.
The not-so-cheap-but-dirty solution is a LensBaby, but it's rather uncontrollable.
I think there's a Russian T&S adapter called an Arsat that works with wide MF lenses.
And if this is a professional|career need, invest in a Nikon system with T&S lens.
The cheapest solution is software. Most modern PP editors have Perspective Control tools, so you can turn trapezoids back into rectangles. This process causes parts of the image to s-t-r-e-t-c-h so you generally need to downsample to maintain resolution. But if you can't stand that resolution loss, you'll need to spend money on an optical solution.
02-10-2012, 05:47 PM   #3
Clicker's Avatar
Prices actually doubled since last year if i remembered correctly
MC 35 mm Tilt & Shift Pentax lens
MC 80 mm Tilt & Shift Pentax lens
pentax made a 28/2.8 TS but i have never seen one in person.
02-10-2012, 06:42 PM - 1 Like   #4
creampuff's Avatar
Traditional T&S lenses are simply not wide enough in APS-C.
You will get better results using a conventional rectilinear wideangle and process in Photoshop CS5.
Not quite the same but good enough.
02-10-2012, 06:56 PM   #5
Clicker's Avatar
In that case i'd like to suggest Sigma 8-16
02-10-2012, 07:32 PM   #6
cpk
cpk's Avatar
The Pentax lens was shift only; I owned one. There is also a Schneider-Kreuznach tilt/shift lens with a Pentax mount; but it is very expensive.
02-10-2012, 07:42 PM   #7
normhead's Avatar
QuoteOriginally posted by Clicker Quote
That is so cool... I wonder if they have one for a 645.... going tilt and shift on an APS-c... I just can't convince myself it's not wrong.
02-10-2012, 08:07 PM   #8
Clicker's Avatar
Z
Hartblei Superrotator
Price List - HARTBLEI & Kiev Cameras and Lenses | HARTBLEI (they maybe out of production best to email first)
There's an adapter for using other manufacturers TS lenses on the 645 and 67....i can't remember sorry
02-10-2012, 08:09 PM   #9
Clicker's Avatar
There's also that tilt shift thing...a few members use it in here...dam the name is on the tip of my tongue.
02-10-2012, 08:10 PM   #10
QuoteOriginally posted by TheM0nkeyM4n Quote
Hi
The Russians have one supposedly with a very good reputation and it has a true K mount.
MC 35 mm Tilt & Shift Pentax lens | rugift.com
Greetings
02-10-2012, 08:22 PM   #11
Clicker's Avatar
hah this is what iwas trying to remember
Lenses for SLR, Mirrorless and PL Cameras | Lensbaby Creative Effects Lenses
02-10-2012, 08:58 PM   #12
Since you will not get lens/body communication with any shift/tilt lens, any that can be converted to K-mount is good. Zuiko, Zeiss, and Leitz are good lenses.
02-11-2012, 07:01 AM   #13
Schneider still offers the 2.8/28 mm PC lens. 28 mm does not feel like a wide angle on an APS-C camera...
There exists no PC lens for APS-C format cameras - i.e. with a design not designated for full frame cameras. You need to accept fairly large distortion and no wide angle feeling. It is much easier these days to use a wide angle lens and crop the image later. You will lose some 30% of resolution because of the crop, but it is going to work. After working with the Schneider lens for years on different 35 mm models, I would not recommend a PC lens on an SLR camera especially not on a digtal APS-C camera for architectural images.
02-11-2012, 08:47 AM   #14
Thank you very much for your guidance and pointing me in the right direction
02-14-2012, 01:23 AM   #15
penties rider's Avatar
of course it's a lot better to use such lenses for perspective control and correction at the time of taking the actual picture, but some slight to medium adjustment of perspective flaws can be done in post production too, using the Perspective 'handle' in Photoshop's crop tool for example ...
surely that's not the best way to go but the main advantage of this manner of perspective correction would be in the fact that when taking the photograph, you don't have to spend time on adjusting the PC lens, while viewing the image through the tiny viewfinder or the still not so big LCD screen on the camera; you just take your picture and leave the rest to post ...
another advantage: more lenses of varying focal length can be used ...
camera, control, dslr, k-5, k-5 ii, k-5 iis, k5, lens, pentax k-5, perspective
D700+non-VR lens from Pentax perspective yusuf Non-Pentax Cameras: Canon, Nikon, etc. 22 01-19-2012 05:26 PM
Getting my lens lineup under control bdery Pentax SLR Lens Discussion 20 08-23-2011 08:09 AM
For Sale - Sold: K10d, 18-55mm lens, remote control F cyclocross Sold Items 2 09-20-2010 06:42 AM
Camera and Lens Quality Control? benjikan General Talk 33 03-26-2010 06:39 PM
Best fixed focal length lens for architectural photography on a K10D nanter Pentax SLR Lens Discussion 29 10-25-2008 09:21 PM
All times are GMT -7. The time now is 01:36 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
