02-10-2012, 11:49 PM   #1
Fingerprints in viewfinder
Finally I bought the Pentax K-5, after shooting a number of indoor pix I decided to depict outdoor. ... Surprised to see that there is something like fingerprints when looking through the viewfinder!!! I informed the agent and they decided to maintenance and change the viewfinder after all they returned back after replace the viewfinder with number of fingerprints increased!!! They said : all pentax cameras have the same problem!!! Is this a true? Please reply guys
thanx
02-10-2012, 11:50 PM   #2
Those aren't fingerprints, that's the way the focusing screen is made. The circular pattern becomes visible when you have slow lenses mounted on your camera (typically > F5.6) or you stop the lens down to a low aperture setting. Try using the DOF preview feature and you'll see it
So to fix the problem, try a faster lens
02-11-2012, 12:02 AM   #3
thnx brother Adam
i"ll try it ....hopefully....who knows
02-11-2012, 12:15 AM   #4
crewl1's Avatar
This needs to get added to the sticky - similar to 'why does my camera make a clunking noise?'
07-13-2012, 03:18 PM   #5
CMG
I had the same issue
I just found your thread...right after I started a similar one here (https://www.pentaxforums.com/forums/pentax-k-5/192400-fingerprints-grit-new-k5-kit-lens.html). As you can see, I returned my kit and a new one is on the way. I'm no optical engineer, but it seems odd to me that slower lenses would only be plagued by this problem...again, I have no idea about the physics involved...but I'd really like someone to explain in more details why this is the case and how it serves the proper functioning of the K-5 (Anyone??). I didn't have the problem with my FA-31 lens which is significantly faster than the kit lens...so that supports the slow lens theory.
07-13-2012, 03:54 PM   #6
crewl1's Avatar
If you stop down your FA-31 and use the preview switch (rotate the on-off past on) you will see them.
With modern lenses your view through the eyepiece is done wide open.
I think because fast lens will pass more light directly through the center, whereas a slower lens is more balanced light from the sides and center causing the ridges to produce shadows so they are more visible.
(I dont know that this is the case I'm sure there is a scientific explanation someone will add.)
The rings are there to allow the focus screen to act as a projection medium for the image coming off the mirror.
Pentax uses this fresnel ring design, maybe other manuf use more of a frosted design?
camera, dslr, fingerprints, k-5, k-5 ii, k-5 iis, k5, pentax, pentax k-5, viewfinder
ME Viewfinder slh Troubleshooting and Beginner Help 3 07-30-2010 03:09 PM
time's fingerprints sheela Monthly Photo Contests 0 03-24-2010 09:20 AM
K200D viewfinder + Katzeye VS. K20D viewfinder dugrant153 Pentax DSLR Discussion 3 07-24-2009 11:36 AM
Worried about scratches and fingerprints on your lens? soccerjoe5 Pentax SLR Lens Discussion 7 12-14-2008 03:53 PM
K200D Viewfinder vs K20D Viewfinder cputeq Pentax DSLR Discussion 7 06-15-2008 11:57 PM
All times are GMT -7. The time now is 08:01 PM. | See also: NikonForums.com, part of our network of photo forums!
