03-06-2012, 09:49 AM   #16
I made one of these up using a small project box, the smaller 10 watt SWAD regulator rather than the 25 watt one and a cigar plug. Works great. I use a portable battery booster as well and it lasts for many hours even on cold winter nights. I anchored the regulator in the project box with industrial velcro. If you want an alternative to soldering the tiny contact pins on the regulator and have access to computer parts, hunt around for the three prong leads that connect older IDE CD-ROMs to the motherboard. Should slip right on.
If not, you can use two of the smaller Power and Reset two-wire switch cables and leave one of them unconnected.
Jack
03-06-2012, 09:52 AM   #17
LaurenOE's Avatar
Very Nice!
03-06-2012, 10:02 AM   #18
mtansley's Avatar
QuoteOriginally posted by FlashJT Quote
I'm still a little concerned about the fact that the regulator can be adjusted. Worried about it getting changed somehow and screwing things up. I'm entertaining the idea of removing the potentiometer from the regulator, measuring the resistance that is giving me 8.3V out of the regulator, and then replacing the potentiometer with a fixed value resistor. Then no worries about accidental voltage changes. No rush to do that just yet, but if I do go down that path I'll post back here with how that goes.
Isn't there some sort of almost paint-like substance that manufacturers sometimes put on adjustable pots to stop accidental movement but it can still be adjusted with a screwdriver?
Or even a bit of nail polish?
03-06-2012, 03:33 PM   #19
Ex Finn.'s Avatar
QuoteOriginally posted by mtansley Quote
We used, still do, nail-polish to lock down potentiometers, just let is dry before closing up the enclosure.
12-14-2012, 10:18 AM   #20
Tom S.'s Avatar
QuoteOriginally posted by marklev Quote
That sounds like an awesome idea. Can you please test it and let us know about the total timing of car battery with this adapter and without the car engine running?
That's almost impossible to state. All cars take different batteries. Case in point my truck, a diesel, has two batteries, each one larger than those found in many small cars. It also depends on the battery condition and age. Lastly, it would depend on the kind of battery.
Suffice to say that on a battery in good condition, it would run for a long time.
battery, camera, device, dslr, k-5, k-5 ii, k-5 iis, k5, lot, pentax k-5, plug, telescope
K5 - USB or 12V Battery Recharging PentAdam Pentax Camera and Field Accessories 4 12-26-2012 05:16 PM
Trigger voltage? - Lester A Dine Clinical Box Power Supply Model II (ring flash) Nick Siebers Flashes, Lighting, and Studio 5 02-10-2011 11:50 PM
Alternate power supply for flashes? amoringello Flashes, Lighting, and Studio 5 09-03-2010 07:43 AM
Possible DIY portable Power Supply for Studio Strobes - ADVICE NEEDED MRRiley General Talk 4 09-11-2008 05:40 PM
Charger/Power Supply jnorth Pentax DSLR Discussion 15 01-07-2007 10:47 AM
All times are GMT -7. The time now is 05:47 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
