02-21-2012, 11:46 AM   #1
LightSpeed's Avatar
Help!!!! My K5 has gone nuts.
So I take the Kenko auto extension tube off, and put the 100mm macro WR back on ( without the extension tube)
All of a sudden the camera prompts to input focal length.
Fine I input 100mm
Next thing you know auto focus doesn;t work............and the F number is blank on the top screen ( next to the shutter release button)
Second problem : I have the camera set to NOT fire when subject is not in focus.
CAMERA FIRES AT ANYTHING...........IN FOCUS, OUT OF FOCUS.....YOU NAME IT, WITH LENS CAP ON.
This things gone crazy.
02-21-2012, 11:48 AM   #2
Have you cleaned your lens mount and all the contacts? That's most likely the problem. Also make sure your camera is in AF mode.
02-21-2012, 11:51 AM   #3
philippe's Avatar
If what Adam said does not work, then take the battery out, count till ten, and put it back in again. If this does not work, send your camera AND lens in for repair.
Sorry for your grief...
BTW, did one ever wondered why Pentax does no more carries extension tubes, there must be a reason, not?
02-21-2012, 12:18 PM   #4
lammie200's Avatar
Reset as well...
QuoteOriginally posted by philippe Quote
I would try a reset as a last resort before sending it in for service. Just saying...
02-21-2012, 12:32 PM   #5
To get the camera to operate with the Kenko tube you would surely have had to alter settings. Can't think what though.
Anyway, check your settings and re-set where necessary. The camera will not revert automatically.
02-21-2012, 12:44 PM   #6
LightSpeed's Avatar
Fixed.
All I did was wipe the contacts off.
To get the camera to operate with this Kenko extension, no setting need to be altered.
It's a 25mm auto focus extension tube for Pentax.
Bougth it from a forum member here and it works like a charm.
02-21-2012, 12:44 PM   #7
LightSpeed's Avatar
Thanks gentlemen.
02-22-2012, 12:37 AM   #8
philippe's Avatar
QuoteOriginally posted by lammie200 Quote
Why? I am just curios...
100mm, auto, camera, dslr, extension, focus, input, k-5, k-5 ii, k-5 iis, k5, pentax k-5, tube
Nature I'll Crack Your Nuts! Rupert Post Your Photos! 3 07-27-2011 09:20 AM
So one of my photos went nuts on the net.. Usuqa Photographic Technique 27 07-07-2011 11:24 AM
Fruit, Nuts, and a Bowl martywk Monthly Photo Contests 2 06-11-2011 03:03 AM
Misc This is nuts !!!! Workingdog Post Your Photos! 2 01-09-2011 09:11 PM
Nature Chickadee Goin' Nuts ajuett Post Your Photos! 18 04-14-2010 06:45 PM
All times are GMT -7. The time now is 04:46 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
