02-29-2012, 01:42 AM   #31
QuoteOriginally posted by tonyrodgers Quote
I did check for sensor stain shortly after I bought the camera and I was fairly sure I had it - i.e. small rather reddish dots which showed above about F16 or so, but not at larger apertures.
maybe that was a dead pixel? there is some kind of allowed amount of them which is not considered a defect.
there is a menu command somewhere, 'map pixels' or something like that - it removes those dead pixels so they dont' appear on the shots any longer.
02-29-2012, 01:53 AM   #32
tonyrodgers's Avatar
Hi PeterF, there are a number of ways of looking at the exif information in a photograph - many graphics software packages do this. I also use "exiftool" ExifTool by Phil Harvey which I run on a linux desktop - there are windows & mac versions available too. If you post on Flickr it will also display exif...
02-29-2012, 05:34 AM   #33
I want to thank everyone for their replies. I downloaded both of the recommended programs and I now have the information on shutter count that I needed. I can see that I am really going to enjoy being a part of this forum.
02-29-2012, 09:14 PM   #34
I just purchased a K-5 body and the serial begins with a 418, I should be clear from the staining issue, right?
02-29-2012, 09:23 PM   #35
Check the serial number
The shutter count is not really an indicator of sensor staining. Only early serial numbers (starting 38... 39....) seemed to have this problem. You can check the K-5 serial number database at Pentax K-5 Serial Numbers - Pentax Serial Number Database - PentaxForums.com
03-01-2012, 02:59 AM   #36
So using the tool on the PF site to check the shutter count and manufacture date, my details are:
Camera PENTAX K-5
Manufature Date 2011:07:31
Shutter Count 1
That should be well out of the sensor staining batches, right?
03-01-2012, 04:29 AM   #37
QuoteOriginally posted by Munki Quote
Camera PENTAX K-5
Shutter Count 1
More of the serial number than the shutter count. Shutter count is used for checking the number of shutters that you have pressed on the K5 or any camera.
New batches of K5 should not have the stain issues.
03-01-2012, 04:43 AM   #38
QuoteOriginally posted by felixkh Quote
I was more hinting the manufacturing date of the unit as a point for the sensor stain issue. The shutter count was only for the benefit of this thread's topic.
My previous message was regarding my serial number (I was at work and didn't have any lenses to test out, so I had to wait til I got home to use the exif tool). The serial begins with 418xxxx.
I think someone said before that the old ones beginning with 38 and 39 were the ones which were affected?
03-01-2012, 04:55 AM   #39
I think you are right about the serial number range for the stains. Mine is a 417xxxx and its sensor is fine.
03-01-2012, 05:04 AM   #40
I believe K5s manufactured in 2011 should be free of the stains. These were an issue when the K5s were first sold in 2010.
03-01-2012, 05:32 AM   #41
Marketplace Reseller
dcshooter's Avatar
I don't know about the exact situation in Australia, but here in the US, the FTC bans advertising as new any returned product that has been unboxed. In practice, this means that if the original shrinkwrap is gone, then the item must be marked as a refurb. Doing otherwise is considered a deceptive trade practice and can result in a fine on the retailer.
Doing a quick Google search, I came across this link that might give you some edification:
Selling Refurbished Goods As New May Be Common Among Australian Retailers | Gizmodo Australia
03-01-2012, 05:43 AM   #42
They've actually recently caught major retailers here doing that, dcshooter. It's technically illegal, if I recall correctly.
To add context to the K-5 though, mine wasn't shrink wrapped, and I don't think they usually are? So how would you know for sure?
Edit:
QuoteOriginally posted by JimDickinson Quote
Thanks for the confirmation guys.
03-01-2012, 06:46 AM   #43
dcshooter's Avatar
I'd say 3k shutter actuations might be a clue!
In all seriousness, though, I was rather shocked and amused to see in the article that I quoted that retailers have been caught reboxing hard drives full of pirated movies as new without even bothering to check their contents first!
03-01-2012, 08:03 AM   #44
mickeyobe's Avatar
Did you put in a used memory card from another camera?
Mickey
03-04-2012, 01:59 AM   #45
Yes I did, but formatted before using. However the camera shutter count is stored somewhere (?) in the camera firmware and shouldn't be affected by memory cards.
I've seen those references to Australian retailers illegally selling used goods as new, which is one of the reasons I decided to take this (refurbished?) K5 back and ask for a new one.
However it is taking a LONG time - well over a week already. The delay seems to be with the Pentax distributors (CR Kennedy) who are yet to respond. I'm hoping I don't have to take it the next stage (i.e. a formal complaint to NSW Fair Trading) but if they delay much longer I will have to do that...
camera, count, dslr, k-5, k-5 ii, k-5 iis, k5, pentax k-5, shutter, shutter count
K5 with Zero shutter count? 41ants Pentax K-5 9 04-20-2011 12:53 AM
Shutter Count aaalegre General Talk 2 02-13-2011 10:27 AM
Shutter count of K-5 Edvinas Pentax K-5 4 11-12-2010 10:19 AM
Shutter count neil1 Pentax DSLR Discussion 13 11-09-2010 09:19 AM
Shutter count of about 80 on a new K-X? causey Pentax DSLR Discussion 18 05-14-2010 07:01 AM
All times are GMT -7. The time now is 02:14 PM. | See also: NikonForums.com, part of our network of photo forums!
