Originally posted by MSL Ok, let me rephrase this question. Knowing that the center spot may focus on the wrong place - might it help to use one of the side spots and recompose, or does it help to focus away and focus back, or does one need to treat the lens a bit like a manual focus under these conditions and occasionally adjust the focus.
Since they are all roughly the same size I doubt it would make much differance. At least with the centre you have an accurate marker with the circle. What i have now done, is simply be less critical. Instead of focussing on an eye, i place the circle over the face. I now know that at worst it may focus on the end of a nose instead of the eye. It may not be spot on... but close enough.
Obviously, if you can stop down a bit, this will hopefully cover the gap with the exrea DOF. If your subject is static and critical focus is important then manual focus would prob be best but its not always poss.
A lot of people like to shoot really fast lenses. Those that do will have to concentrate far more on this.
Focus is always critical here with such a shallow DOF.
